Originally Posted by bobby2478
Interesting, thanks for the info as I wasn't aware of that. I don't see this in Assassin's guides, am I missing it or isn't it referenced there? Once you install MPC-HC do you need to do anything special to get it to work with WMC/MB? You mention it's an external player, does it seamlessly play videos from within MB? Meaning you navigate your library through MB, and when you play an item it plays it seamlessly on MPC-HC, and once playback is over your back in MB.
It can be set up to do with a remote I believe but I have a mini RF keyboard. If you right-click it brings up MPC-HC's vast menu. from there you can navigate with a mouse.. I use the track pad on the keyboard.
For chapter skip, I have it mapped to my H-900 remote via the cutomizable settings in the MPC-HC menu.
Isn't that overkill? I have a 670, but I use it for gaming. I have tested that GPU with madVR (all 3 algorithms as Jinc) and it's perfectly smooth, but I don't know if you have to go all that way to get that quality. BUT there is another side, I like to future proof my builds. If someone says that my configuration can stand for a long time, I rather invest now than keep on upgrading everytime.
), and a PSU, as my current just comes with one 6-pin plug (two are needed for both 660 Ti or 670).
