Originally Posted by HunterX82
Well thanks--I don't see a "contact" on your website otherwise I would use that, sorry!
Do you know why I would blue screen when I change my SATA mode to AHCI? Unless I keep it as IDE, I bluescreen. All of the other optiosn in your bios guide work just fine.
My HDD is SATA, this motherboard doesn't even have IDE connections.
You need to install it while in AHCI mode. The guides are meant to be followed in order.
There are registry hacks to change this after installation but I take no responsibility if it causes an error to your system.
BTW my e-mail is on the front page of the blog site. Always has been.
Most just look at pictures
, maybe keeping things like that around for reference could be moved to a "reference" tab. I agree with your wording, just suggesting that the format is a little off, and the "Skip to Setup" link is not prominent enough to keep a first timer from entering those "reference" sections
). The only that I'm left with is the Antec Twelve Hundred v3.
