Sean - That was one heck of a post! To answer your questions...
Originally Posted by
230-SEAN
I understand that with a blu-ray drive I will be able to watch my blu-rays and possibly even save them onto a hard drive and create something like a movie jukebox, right?
Absolutely. Most use a program called makemkv to rip them onto their hard drives. You can also use a program called handbrake afterwords to skrink the size if you want. Makemkv is free for 30 days at a time (for now) and takes 30 minutes or more depending on the size of the movie and the speed of your drive. Handbrake is free and can take many many hours (and is only needed if you want to shrink your movie which causes a loss in quality).
230-SEAN
The Sandy Bridge appears to have 3d capabilities, could this go as far as 2d to 3d conversion? If so, what software would be needed?
You need playback software like PowerDVD or TMT5. Both are around $100.
230-SEAN
Is there anyway to have a dual hdmi output allowing the bitstreaming of HD audio out of one hdmi port and the HD video out of the other hdmi port?
Just buy a DVI to HDMI cable and you can use the DVI and HDMI ports on most boards.
230-SEAN
I read that you have the ability to choose aspect ratios, does this include vertically stretching an image (or removing black bars top and bottom) for use with an anamorphic lens? If so, can this be done with 3d blu-rays as well?
This I don't know. I never remove the black bars as I think it compromises the movie, personally.
230-SEAN
Is there a software that can be used as a final video processor prior to sending the video out? Would such a software include a Color Management System, noise reduction, etc.? Would an HTPC with said software be comparable to a Lumagen video processor?
There are a lot of post-processing options available. Do a search in this forum and you can find them. I don't do this personally as I find the picture just about perfect.
230-SEAN
I see that some cases have lcd screens on the front, what benefits do these screens give you?
Very little unless your HTPC is located in a media closet that is not in view of your viewing area. This allows you to make changes on the HTPC case screen without being able to see the regular viewing screen. Personally when my HTPC is viewable I want as few lights as possible visible.
230-SEAN
How do you navigate through the HTPC? Do you need a keyboard and mouse or can you use some sort of remote control?
You can use either once it is all set up. You will obviously need a keyboard and remote for the initial setup.
230-SEAN
I read that irule allows you to control WMC, however I plan to do a full irule install using global cache hardware. Is there anyway to control a HTPC via RS-232? If so, would the control be limited to basically just turning the PC on and off?
Yes, this is possible. It even seems like there is a post devoted to just this subject as was mentioned above by someone else.
230-SEAN
I'm sure I will have more questions in the near future, and I apologize if some or all of the above have been asked and answered, I just hadn't run across them as of yet. Thanks in advance!
You are welcome.
