AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Simple/Beginner HTPC Buying Guide
Assassin's Simple/Beginner HTPC Buying Guide - Page 264
post #7891 of 15486
Good point cburbs. I would also play the .mkv file from your computer to see if it runs smoothly as an initial test. You may need to down load a codex pack so you can view mkv's from you pc if you have not already done so.
post #7892 of 15486
Even with the new PS3 MS version and Serviio I still have the same issues. Some movies are good and some skip. Doesn't matter if it's a SD DVD or Blu-ray either. Some times I notice I get a Media Server error as well and the movie can't be displayed.
Edit**
I recently installed the OS. I just built this HTPC a week ago. I can try all the same cables, but I'd have to order cables from monoprice so I'm looking at early to mid next week before I'd get them. I am playing my Media files from within my HTPC. I have a SSD for the OS and 2 Samsung 2TB Drives for the Movies. Only using one now seeing how I haven't filled it up yet. I watched a few of my kids SD DVD's and blu-rays with her over the course of the last few nights and everything appeared normal to me. Also if this matters I streamed Netflix through my PS3 and through my recent HTPC build with flawless results and I was on wireless with both. I never really "needed" to go hardline until recently when I have been trying to get this whole PS3/HTPC thing to work.
As far as what I am using to encode the MKV's, I haven't downloaded any codes. I was using what ever came with PS3MS. I did however download and install FFDShow to see if that would help and once it didn't I deleted it. Unless the LAV program contains codecs? I have to read exactly what it is again. When I followed Assassins guide I downloaded it as he said. Once I did that I downloaded the MKV burner. All I do is use MKV to burn the disc to the HD, then open Media Center Master so it downloads the cover art and what not and when I'm ready to watch the movies I open Media Browser.
judd
post #7893 of 15486
At least you know the ps3 is working fine if you able to watch netflix. ffdshow can have mixed results and removing it can be difficult. Based on what you said about ur configuration, it is pretty close to mine.
I would still try a direct ethernet cable from pc to ps3 and see if that helps. To view mkv's from pc, DL the combined community codex pack from:
http://www.cccp-project.net/download.php?type=cccpi
To install do the folllowing:
1. It may ask you about latest D3DX9 and if you want to proceed anyway. If so click Yes.
2. Click Next, and select default destination location.
3. Only check the FFDSHow Tryount and Haali Media splitter.
4. Chose defaults for everything else.
After that installs, test playing a mkv file from you pc using windows media player. It should run nice and smooth.
If you are making your own .MKV files that could be the issue as well. Try downloading some .mkv sample movies from the web and test those out. I doubt it is anything to do with your machine or ps3.
Good luck and let me know how it all works out.
post #7894 of 15486
Originally Posted by wbburden View Post
Would I be safe following this guide for a WHS 2011 server? I'm looking at a G620 processor and H67 motherboard? Anything I need to watch out for?
Originally Posted by StardogChampion View Post
If you want to start a separate thread for this subject, it's something I'd like to talk about too. I'd offer some ideas but I don't want them to get lost in this thread and it's off-topic. I've been doing quite a bit of looking into the home server side of things lately as I get ready to migrate mine.
Originally Posted by Wilky13 View Post
I am also interested on WHS. Can you link the thread about it on this thread for others to find?
Here is the link to the new thread.
post #7895 of 15486
So are you using Makemkv to rip your movies/blu rays - that was what I was getting after.
Give us a movie that is causing problems and what you used to rip it -
post #7896 of 15486
I realized that I dont like gaming on my projector. I prefer the brightness of my LCD and also dont like the fact that Im using up a lot of the 8700's bulb with gaming. So I want to move my Geforce 560ti to my desktop.
But I was wondering if there's a way to get HD audio over the motherboard's (Gigabyte Z68MA-D2H-B3) optical out to my receiver (Onkyo TX-SR876). Or if I hook it up via the mobo's HDMI out, can I get HD Audio that way? Right now I have it hooked up via my 560's HDMI out and I can get DTS-MA and TrueHD out to my receiver.
Or do I need to buy something cheap like this GT520 http://www.newegg.com/Product/Produc...82E16814127583 to bitstream HD Audio to my receiver?
post #7897 of 15486
HD Audio can't be bitstreamed over optical. Only HDMI.
You can use the onboard iGPU (assuming you have a capable CPU and MB) or get a cheap card with HDMI out (like the NVidia 430/440 or ATI 5xxx/6xxx)
post #7898 of 15486
thanks assassin for the quick reply
post #7899 of 15486
post #7900 of 15486
Looks like a great build.
Your PSU needs to be under 7 inches in length for that case. It looks like both of those will fit but check to make sure.
post #7901 of 15486
What's the efficiency rating on the VP-450? I can't find it, even on Antec's site. It's part of their "Basiq" line so it might not be 80+ certified.
I'd look at this Antec PSU: http://www.amazon.com/Antec-EA-380D-.../dp/B002UOR17Y as well. It's 80+ Bronze.
post #7902 of 15486
Yea I used MakeMKV to rip the Movies to the Hard drives. After I rip them with that program I don't do anything else to them.
I've watched movies from my HTPC hooked up to my 50" Samsung Plasma and my PJ projecting a 120" screen with NO issues. As far as certain movies causing the issue(s) it various. I've had issues with some 1080p Disney Pixar movies like Cars and even some SD DVD's like Over the Hedge. At first I thought maybe it couldn't play the 1080p videos, but when I tried a few more then mixed in some SD movies it didn't seem that that was the problem since it happened here n there. I think my biggest Blu-ray size wise right now is Dark Knight, and that movie plays flawlessly.
I need to try hooking my PS3 directly to my HTPC like mentioned a few posts earlier. I also think there was a cccp codec program I was told to try. I will try both of these one at a time (PS3 to HTPC first) and then report back. Until then can anyone think of anything else?
PS I appreciate the help and Assassin not yelling about me posting here
Judd
post #7903 of 15486
Judd
Just thought that I'd add my 2 cents. If you've followed Assassin's guide, I'd stay away from installing any of the codec packs. I have no issues streaming MKV's to my PS3 with PS3 Media Sever over a gigabit network. My setup is with CoreAVC, Haali, DirectVobSub, and I've got AVIsynth installed as well. I've had less issues with using AVIsynth/Mencoder as my default player than the other options.
post #7904 of 15486
I just tried the codec pack above and the same thing still happens!
FEVER: Did you just dl those codecs and it automatically used them in PS3MS? If so maybe I should try it. When I go to the file on my PS3 it says title00.mkv [MEncoder]* next to all my movies so I would think the MEcoder is installed.
This is frustrating
Judd
post #7905 of 15486
This is frustrating
Judd
I paid for CoreAVC, because it's a good alternative for hardware acceleration on my htpc and desktop (both run Nvidia cards). Let me figure out my exact settings and I'll get back with you. I'm house sitting, so I'm not next to my PS3 at home.
post #7906 of 15486
alright I'm ready to go out back and play some target practice with the PS3 since this crap isn't cooperating.
post #7907 of 15486
Stardog - Thanks for the note. You are correct. It is only "up to 75%" Efficient per their flyer on the Antec site. Edited out the build above to include the EA-380...
post #7908 of 15486
If you go with the EA line make sure to grab a power cord if you don't have one as the Green line doesn't come with one. That's parts of their "green" thing.
post #7909 of 15486
Thanks for the note. I edited the PSU to get the EA-380D per Stardog's recommendation on the 80+ certified Dimensions are 3.4" (H) x 5.9" (W) x 5.5" (D)
Thanks for the reminder. I think I probably have a few lying around here, but your note was a good reminder.
post #7910 of 15486
"Amazon.com Thanks You"
That's the note I just got after hitting the Place Order button. Thanks again to all.
I guess now I need to buy Assasin's guide and begin reading. Is there a difference whether I Donate via Paypal in the first post of this thread, or go directly to the Blog to purchase?
post #7911 of 15486
You have to go to the blog. The software is automated on the blog and should send you the signup information automatically.
Thanks for the support. You are going to love the guides.
post #7912 of 15486
I just tried having my PS3 connected directly to my HTPC and movies still skip
Judd
post #7913 of 15486
Judd
Do you have any other streaming devices available or just the ps3?
Take a movie that is a problem - make sure you have the latest makemkv version and re rip the movie - don't delete the old one and see if the movie has issues or not...that would be my next test.
post #7914 of 15486
Both work.
I like using just LAV because its easier to use and has much less options to adjust. With Shark there are almost too many options and literally probably tens of thousands of possible combinations.
Why do all of that when LAV works so well and is so easy to use?
Why not just use the Live TV button on your remote? That will launch you automatically into Live TV.
Dude I am lmao about the live tv button. I didn't even know it was there friggin awesome! That is my opinion exactly about the shark set up. If lav is so easy that is what I need to do, because with the shark when I have a problem there is like 30 different settings I have to check and uncheck and stuff. I will look into lav soon.
post #7915 of 15486
Judd
Okay, here's how I have mine setup and working:
Go to this link to download AVIsynth and Vsfilter. I zipped them up for you.
Make sure PS3 media server is not running.
Install AVIsynth, and just let it install to the default location. When it's done installing, copy the contents of VSfilter (4 files) to the root of your C: drive. Right click "vsfilter_enable.cmd" and click run as administrator. Your cmd prompt should pull up and give you 2 confirmations that vsfilter and vsfilterx64.dll were registered. Now copy the two dll files and go to the plugin folder of AVIsynth. Mine is C:\\Program Files (x86)\\AviSynth 2.5\\plugins. Paste the two .dll files into this folder and exit out. Open up PS3 Media Server, and go to transcoding settings. Under video file engines on the left, if AVISynth/Mencoder has a "Red X" next to it, instead of a "Green Arrow", then click AVISynth/Mencoder and then click the little plug looking button on the bottom to load the engine. Once it does that, you'll have to restart the HTTP server, so do that at the top. If it already has a green arrow next to it, then don't worry about it. Then click AVISynth/Mencoder and click the up button on the bottom to make it the first priority engine, and restart the HTTP server, and that's it.
This is how mine is set up, and I have no issues whatsoever. Here's a screen cap of mine, so you can see my settings.
Also, be sure to check your transcoding folder to see if any of the other options in there might work for you.
post #7916 of 15486
thefever,
I also have CoreAVC but have not set it up for PMS. What addtional settings do you use for AVIsynth and Vsfilter to get CoreAVC (cuda) support. Also, when your streamig a movie to the ps3, do you see the CoreAVC icon light up green in ur taskbar?
post #7917 of 15486
Originally Posted by ravex911 View Post
thefever,
I don't have any extra settings except for what I described above. I use AviSynth/Mencoder engine in PS3 Media Server. When I'm streaming a compatible mkv (one that's not encoded in xvid), my coreavc icon, haali icon and usually my directvobsub icon pop up.
Edit: Check out this link.
I followed it some when setting up, but didn't install the Core Codec Pack.
post #7918 of 15486
Fever, I appreciate you doing that for me. I am now green and Avisyn.../MEncoder is now at the top. Now the issue is it seems to skip on EVERY movie and there's no sound for the movies that had sound. I am definitely thinking this is a software issue of some sort given all my issues lately.
Stupid question, but when your in the PS3's dashboard so to speak and go to Video you see your PS3MediaBrowser and Window Media Player ( I believe ). I would always select PS3MB. Is this right or should I be going in the Windows Media Player? If so I'd have to set it up. I am sure I am doing it right. It just crossed my mind to ask.
Judd
post #7919 of 15486
Judd
I always go to PS3 Media Server. When you're navigating your folders on the PS3 inside of PS3 Media Server, have you tried selecting any of the options in the transcode folder?
Edit: Also, don't know if you've tried this yet or not, but have you tried changing the network cable from the PS3 to the router or switch?
post #7920 of 15486
I am trying to boot up my computer for the first time, and I am using the ASROCK Pro3-m. When i go to the UEFI menu, it is asking me for the password. I have tried searching the manual, quick installation guide, and Google. does anyone know what to do.
