Originally Posted by Tizi
Assassin, just finished another build using the G620 and MI-008 case. I used the stock heatsink on the G620 and it touches the PSU as you indicated in your tutorial, is that going to be a problem? I noticed the temps on one of the cores is about 8 dgrees C higher than the other...not sure if that is why. Have read that is fairly normal, but this is the first CPU I have that does this.
You can make it work if you want. Now you see why I pointed out out though. keep an eye on your temps and noise.
. I Need to build a massive server big enough to house my 1000+ DVDs, 1200 Blu-Rays, & DVR recordings first and even that'll have to wait because hard drive prices.
