Originally Posted by assassin
Something else to consider --- do you need the reset switch? I understand wanting to get what you paid for. But you don't really need it. My 2 HTPC cases don't even have one.
Just something to consider. You can always hold the power button down for 5 seconds and that turns off your PC manually (not recommended unless needed of course).
BTW I also don't attach the HD Activity leads to the motherboard on my own personal builds. The flickering light is a distraction on my HTPC.
I've never used the reset switch on any of my HTPC builds either, including my 3rd build once my parts arrive. If its on 24/7 anyway that RS will never see any use.
