AVS › AVS Forum › Display Devices › CRT Projectors › I need to replace lvps fan for marquee 9500. Source/model?
post #1 of 4
I am thinking of replacing the two fans in the low voltage power supply of my marquee 9500. Its already 10 years old and I can hear some noise from one of the fans.. I have put it up for sale and I want to replace the fan, before I sell..
I don't want any fan mods.. just want to replace with the OEM fan..
it is listed as nmb 3610KL-05W-B20. 24vDC .07A
At this site
http://parts.digikey.com/1/parts-kws/index2868.html
they have two:
1. 3610kl-05w-B20-D00
2. 3610kl-05w-B20-g00
i can't tell the difference between the two..
Which one is the correct one?
Yes, my projector has been verified, when it was new, that it never had the "low voltage problem" which some of the projectors needed the fix for (the problem which caused tube filament burn out in some projectors..
Mine had been serviced by Tim also in the past.. but I don't think I had him do the lvps fan mod.
The fan noise has never been an issue.. just trying to replace them.. before selling it - because it is easy for me to do so..
post #2 of 4
I have some extras if you want just paypal me the shipping. I'll use a flat rate small box, 5 bucks.
Athanasios
post #3 of 4
Hey Thanks!
i will send you pm..
Can you send me two.. only one is noisy but I might as well replace both.. because I am selling it.. so that the new owner will not have to worry about changing the 2nd one in the future..
post #4 of 4
thanks for the offer athanasosis.. I ordered them today directly..
  Back to Forum: CRT Projectors
