I just saw your edit on your own post:
Do you think audio over DVI port is disabled in my mobo?
Originally Posted by renethx
1. This works if and only if HD audio controller of the GPU supports dual audio stream, and only NVIDA and Intel GPUs support it. One audio stream is assigned to AVR, the "secondary" display, the other to the 3D display, "primary" display, in extended desktop mode. Select AVR as the sound playback device in the player. BTW HDMI and DVI with a DVI-HDMI adapter are completely equivalent in NVIDIA and Intel (audio over DVI port is disabled in some LGA 1155 mb, however).
