Got this case yesterday.
http://www.fractal-design.com/?view=...gory=2&prod=48
I was looking at Lian Lis but I couldn't find anything as exciting as their old v1000 silent case. Silverstones with bottom mounted fans were another consideration but I like clean features and doors. I considered smaller cases but those with several HDDs are big enough not to fit in the theater rack and a waste of space beside it.
CPU coolers will be Scythe's Big Shuriken and Samurai zz. Didn't think I needed to obstruct the air flow with a monster cooler. I don't know how quiet these two will be under high loads. Should have gone with Gelid Tranquilo perhaps.
I'd like to see those fanless new Radeon HD 6770/6570/6540s.
PSU Seasonic X series 560. I need another. I am considering the fanless one but it'll need babysitting and the whole concept is a bit too experimental.
If you have four slots, check the manual and see which ones need to be used first. Or don't. It just won't boot.
