Hi,
I have recently acquired an iPad and would like to give a shot at controlling my Home Theater from the iPad (using iRule). Current remote set up is:
URC MX-850
URC MRF-350/250
I see the MRF-350 has a separate IR input on the rear pan. I'm wondering if any one has tried connecting a Global Cache iTach WF2IR to the MRF-350? If so - can you reply with details?
This seems to be the only way to use my iPad without replacing key components (and, as a result, making my MX850 useless which I definitely don't want to do). Other thoughts input to controlling this set up from the iPad?
Thanks in advance
URC MX-850
URC MRF-350/250
Thanks in advance
