Due to recent demand, I have decided to start an informative thread on which drives do and do NOT work as replacements for the retail Moxi boxes (not the chartered cableco boxes). As anyone who has had experience doing this process can attest, it can be a lengthy and immensely frustrating exercise.
Please contribute with the following:
I'll kick things off with the following:
Good luck and happy posting!
**Edit** You may also want to include whether this was tested as an internal or external hard drive. Depending on the model, the same unit may work one way but not another.
- Your equipment, ie. whether it's the 2 or 3 tuner model. Please do not post that it's a MR-1500T3 box, because both units (for no good reason) use the exact same model #
- The hard drive model # and specs (Manufacturer, capacity, RPM, cache size)
- Firmware version, if you have it available
- Success or failure
| Moxi 2-tuner DVR |
| Samsung Spinpoint F4 HD204UI OEM 2TB 5900RPM 32MB cache |
| Firmware v.6.1.1.9R4BR-P.319355 |
| FAILURE |
) that the Samsung 1.5 TB 5400 RPM works well after being dropped into an external enclosure (on the 2-tuner). I might take the leap and try that one first internally, then if all else fails I will donate more money to seagate.
