AVS › AVS Forum › Video Components › Video Download Services & Hardware › No picture in Netflix on PS3
post #1 of 2
Hardware: PS3, Sony Bravia XBR, HDMI
This happens only on the one TV. Everything on the PS3 displays fine, I fire up Netflix Watch Instantly, the load screen comes up, and then the screen goes blank. If I press the PS button, all of the PS menus come up, so it is likely (obviously?) a Netflix issue.
It worked fine before, then the problem was intermittent, now it is constant.
I've looked everywhere for an answer. I've checked the settings on the TV and PS3 and haven't found anything that seems to be the culprit.
Ideas?
This is using the most recent versions of PS3 firmware and Netflix.
post #2 of 2
Press the PS button, TV/Video Services, Quit Netflix... Then go back into Netflix, the problem should be corrected.
