AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Changing Username/Closing Account
post #1 of 6
I am looking for more information on what happens if you need your username changed or you close your account and start a new one.
http://www.avsforum.com/avs-vb/showthread.php?t=1058446
I came across this topic by doing a search but it doesn't explain what is involved when you close an account. Would my former posts be wiped out? Could I somehow link the accounts?
Ideally, I would like to change the name.
Thanks in advance.
- Lou
post #2 of 6
I have been a long time member under a dif user name but was told they can not be changed, I had to create a new acount and they disabled my old one.
You dont keep any stats, the old posts stay under the old name but the acount is disabled.
post #3 of 6
There is no real reason to change an account. Why sudden change. Why wouldn't it happen again. No real reason in why someone should change a username other then want to.
post #4 of 6
Correct, we can disable an old account and free up the email address to be used to register a new account starting over with a new date and zero post count, however the new account may be flagged & auto-banned as a multi-ID violation over and over which causes more issues then it's worth. Best to stay with your original account.
post #5 of 6
so is this still the policy? or has it changed since this topic was made? i was looking to see if i could change my username, but looks like its impossible?
post #6 of 6
Correct, there's no good (or easy) way to alter the username once registered.
  Back to Forum: Forum Operations Center
