AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › Convert m2ts to Mkv with HD audio
post #1 of 3
Hi,
Does anyone know of a (free) software tool that can convert an m2ts file (with DTS-HD or Dolby True HD audio) into an mkv file, so that:
- The HD audio format is preserved (xcopy stream=yes, DTS downsampling=no)
- The video output is resized from 1080p to 720p
- The video output is reencoded in x264, so the output is smaller.
- The m2ts source file is 20 Gb. Target file should be arround 6 or 8 Gb.
I tried:
- RipBot (encodes to DTS)
- Pav Bluray ripper (video/sound stutters)
- MakeMkv (video/sound stutters)
- DvdFab plantinum 8 (video/sound stutters)
I use MediaPlayer Classic to play these files.
I can play samples of Dolby True HD and DTS-HD
This software works fine.
I also can play the source file (in m2ts format).
With DTS-HD sound.
But this file is big (20 Gb in size).
And is for 1080p (where my monitor only uses 720p)
Can this be done ?
Greetings,
Gent32m
post #2 of 3
The scaling and encoding could be done with MeGUI and the audio can be extracted from the original M2TS file with tsMuxer. The last step would be to combine the new video stream with the extracted audio stream in the MKV container.
post #3 of 3
Is there a tool that can do both (at once) ?
  Back to Forum: HDTV Software Media Discussion
