I will trade you one for your Kuro...
I still think you guys missed the boat on that call...
I had RGB issues with the PS3 a while back and found forum after forum about it with really no clear cut answers.
Apparently, in PS3 "YPBPR", you MUST have Super White ENABLED to see Whiter than Whites. In PS3 "RGB" - no matter what you will ONLY see 16-235, AKA NO Blacker than Blacks and NO Whiter Than Whites. And also it was stated that "FULL" was incorrect for movies and that the correct setting in the PS3 should be "Limited." I will try and find these links. If someone knows differently Please share as I can also benefit from it. -Phil |
With Super White on could you get the whiter than white stars to disappear? No matter what I set the contrast at they would not disappear. Which tells me Super White should be off. You should not see those stars. The checkerboard should fade away right in the middle, and I could not get it to do that with Super White on. TV is a Sony HX800.
