I have a new home under construction, and would like to pre-wire for a security/alarm system. I haven't had time to research different systems, so I have no idea what system I will ultimately put in. Suggestions are appreciated. Preferably something that allows me to choose my monitoring service, with the option for cell backup.
As part of my pre-wire, I plan to go ahead and add the sensors to the ends of the wire. I assume that any standard window/door/motion sensor will be compatible with whatever panel I get. Is this correct?
What brand of sensors do you recommend? Where is the best place to purchase these items, as well as some wire?
Any information appreciated. Thanks.
