AVS › AVS Forum › Display Devices › Rear Projection Units › Mits 57734--thermal sensor code 34/38
post #1 of 2
Hello, I have a 07 Mits 57734 that just shuts off when it feels like it, wether its after 10 minutes on or 10 hours! The code is always 34 or 38 lamp temp high, I have replaced the lamp, no restrictions in air flow at all. Im sure its the thermal sensor connection Ive heard about-- but Im not sure what Im looking for and where (pictures would be nice) Yes I can solder or do whatever to correct this, I just need a little help in locating it and what exactly to do with it? Thanks for the help!
post #2 of 2
Supposedly, that connector is at fault. Cutting off the connectors and soldering the wires is a solution (though, not preferred).
Do you have the Service Manual for this??
You can also try here;
http://www.avsforum.com/avs-vb/showthread.php?t=1256432
http://www.avsforum.com/avs-vb/showt...highlight=lens
http://archive2.avsforum.com/avs-vb/...d.php?t=581146
  Back to Forum: Rear Projection Units
