AVS › AVS Forum › Display Devices › Screens › Jamestown or Elite Please Advise
Jamestown or Elite Please Advise - Page 10
post #271 of 764
Can't speak about the bowing issue (I don't have it), but the wrinkles can be addressed by retensioning the fabric.
What size screen do you have and is it the newer one with the aluminum in the wood?
post #272 of 764
136" wide x 64" high viewable (custom aspect ratio I wanted, CIA more or less). It has the 1x4 poplar (?) frame with 3/4" aluminum hollow square stock on the back - is that what you meant, or actually metal "in" (embedded?) the wood? Not sure about that, nothing that I noticed anyway.
B.t.w. I used Seymour material on mine, vs. the standard material - but I would think the same point about wrinkles would apply regardless.
post #273 of 764
The Jamestown screen is a huge bang for the buck in my opinion. that wrinkling you see is people not taking the time or taking a picture before getting all the wrinkles out. The Jamestown screen is setup to be easily re-tensioned as needed. All his newer screens are reinforced with aluminum square stock as Brad mentioned. I have had no issues with the wood bowing. The only thing that could be an issue is it sagging but that is easily prevented by using multiple mounting brackets to support the frame.
post #274 of 764
I purchased an elite sable frame screen and am quite happy with it. Followed the included instructions rigorously and was able to get a totally flat screen. Installation was easy even for a mechanically challenged person like me. Also, I got amazon prime shipping on it which was a big factor for me.
post #275 of 764
And all is this means.......what? Newbs!
post #276 of 764
About to pull the trigger on a Jamestown as well. Looking at the 130" screen. Just not sure go grey or white. Going to be using a Epson 3010 projector.
Anyone? I think the white will be just fine with this projector.
post #277 of 764
i just pulled the trigger on the 130" in white
i hope it looks good
projector is epson 8350
just could not talk myself into buying a carada screen for $1100
maybe when i upgrade my PJ to a JVC down the road
post #278 of 764
As long as you have decent light control, and decent projector contrast, white is the way to go.
http://www.projectorcentral.com/whit...on_screens.htm
post #279 of 764
How is the Jamestown screen hung? I had a Da-Lite perm wall and the frame drilled into the wall then you snapped the screen in place. With this being tensioned I imagine you have to put it together first then hang
post #280 of 764
You assemble it first, and then hang it. It comes with metal french cleats that can be used to hang it, or you can always use something else (I hung mind with a pair of piano hinges).
post #281 of 764
Any reason why you didn't use the cleat?
post #282 of 764
Yes, I used Seymour acoustically transparent screen material on the Jamestown frame, the screen is mounted on a false wall with speakers behind - I wanted an easy way to access behind the screen when needed, without having to have someone help me take the screen down and find a place to put it. So I have it hinged on the top, so I can pop it open like the hood of a car.
Here's a picture - normally, there are fabric covered panels around the screen top/bottom/sides, but they weren't in place when I took this picture:
post #283 of 764
I know some one I work with who is going to get a custom JT screen for their new projector they picked up so their pj and 120" JT screen will be on the market. Price is a steal from what I was told.,
post #284 of 764
That is a nice set up. A false wall is something I've always wanted to do but I thought I lacked the proper space. How large is your screen Brad?
post #285 of 764
Somewhere around 28' wide.........or 140" wide if I recall lol. I answer because Brad is asleep counting sheep
post #286 of 764
Thanks for the night shift coverage Steve. =)
The screen is 136" wide x 64" high - 2.125:1 aspect ratio.
The room is 17' wide, 23' long - false wall sits 2' in front of the front wall.
First row seating is about 12' from the screen.
post #287 of 764
Just placed my order for a 130" Jamestown white screen for my new epson 8700. Can't wait to get the image on a screen instead of my wall. The bumpy texture on the wall make things unwatchable.
post #288 of 764
I placed my order yesterday and haven't gotten any kind of confirmation from JT. I went to their site and paid through paypal, should I be getting a notice from them?
post #289 of 764
don't worry
he is a busy guy making screens
post #290 of 764
How long does it normally take to get it? I was thinking maybe 2 weeks tops, since it is not a custom size. Will it take longer?
post #291 of 764
I think mine was about 4 weeks, but that was a while ago, no idea how his backlog compares between now and then
post #292 of 764
Mine took nearly 4 weeks and it was also a custom size. I just ordered on Dec 7th and received it somewhere around the Jan 3rd or 4th. It takes a bit for him to get them made up, packaged then shipped. Last I knew he was a 1 man operation so be patient
post #293 of 764
I'm not worried, I don't mind waiting for such a low price. I was just wondering.
post #294 of 764
Same here. I ordered mine Dec 21 and he said it should be here next week.
post #295 of 764
Anyone here compare the screen materials Jamestown uses to other well-known brands (e.g., Da-Lite High Power or High Contrast Matte White)?
post #296 of 764
I ordered a standard 120" screen on 12/19 and each week they tell me it will be next week. Backed up for some reason. I know they are reasonably priced but I'm getting tired of watching movies on the beige wall. (Fortunately thePQ is not as bad as one might think though.)
Jim
post #297 of 764
Received my 125" Jamestown screen frame and Seymour AV XD material earlier this week and assembled and mounted the frame last night. Happy with the quality for what I paid, and would recommend Jamestown. The frame does not have as high as quality a finish as other frames, but when you consider the price, it is very hard to complain.
post #298 of 764
When did they first contact you? I ordered mine a couple of days ago and never got an email or any acknowledgement that they got my order. I paid with paypal directly from the Jamestown website. Just wondering if that is normal.
post #299 of 764
It was one month? I was told 10 business days last week.
post #300 of 764
May have been longer due to holidays (order rush, time off).
  Back to Forum: Screens
