AVS › AVS Forum › Display Devices › Screens › Digital Movie Posters
post #1 of 5
I was talking to a buddy who used two flat screen panels turned vertically and connect a pc to it. The only thing this thing does is stream movie posters all day long.
Now I do not have the money to spend on two panels like that but would a bigger digial picture frame work? I found 24 inch digital picture frames and was wondering if there was a way to turn it vertical and load a punch of movie posters on it.
http://www.digiframes.com/cat/3180/1...re-Frames.html
was the only thing I could find. Let me know what you think or any other ideas.
post #2 of 5
Why not just use some cheap LCD pc monitors, same concept as the frames or tv's but much cheaper.
post #3 of 5
There is software for windows to turn the orientation of the display. On a Mac it is built in to the display options. But there is a much easier way. Just rotate your poster graphics.
post #4 of 5
Also those photo frames are way over priced. Search craigslist for used LCD monitors. I eut you could get a 20' of under 100 bucks. It will give you way better resolution than a photo frame.
post #5 of 5
Awesome thanks fellas
  Back to Forum: Screens
