Originally Posted by michaeltscott
Well, I did run some tests () and things have changed a bit. These are results of my standard 10 minute average minutes 5 through 14 of Ong Bak 2:
Using the 11% increase seen on the PS3, if the 1080p stuff was an aggregate 5.1 Mbps (video+sound), then the new 1080p rate would be 5.66 Mbps; the new 720p rate would be 4.2 Mbps, up from 3.8.
I ran the test on the PS3 3 times to verify my result and twice on the Roku. I think that the old 720p Roku data was off a bit.Code:Old New --- --- PS3 (1080p) = 5.654 6.282 (+.628 11%) PS3 (720p) = 4.299 4.776 (+.477 11%) Roku 2 (1080p) = 5.620 6.217 (+.597 10.6%) Roku 2 (720p) = 4.181 4.752 (+.571 13.6%)
How are you getting the 1080P/5.1 stream on the ROKU 2. I tried 'Ong Bak 2' tonight on my ROKU 2. I didn't see the 5.1 option.
Tomato 10 min average on 'Ong Bak 2' 4.8Mbps - on shows I think are 1080P/5,1 the average is around 5.2Mbps - I tried the Cape Pilot (which I think is 1080P/5.1) and the 10 minute average was 5.2 Mbps see attached
). So the Roku 2 data that I collected yesterday was stereo. According to Netflix, the difference should be 192 Kbps (see
I don't know what conversions are needed to get from Mb to MiB.
). I just need it for half an hour to get my data
