Yeah, the way it works is this:
In 3D mode it gets nasty as well as in "App mode" or whenever I switch to that internet feature (i forget what it is called).
Also, whenever I use a harddrive or lan connection (DNLA i think it's called) it gets that nasty leakage as well.
In 2D mode, local dimming enabled (i guess, there was no feature to turn it on or off) there was no leakage EXCEPT a small amount in the lower right corner. That was where the problem was the worst in all scenarios.
However, it was that bad (in 3D mode and DNLA) that it destroyed the experience. If I saw that in the brightly lit store I would have NEVER bought it.
Some of you might not like the banding issues either.
Ah...that brings a question to mind. Is there any banding issues on edge lit led lcd televisions? I used to see vertical banding on my old sony W4100 but it never bothered me. It's pretty obvious on the LEX8 (H and V), but once again i could live with that.
... unfortunately not all (probably most) consumers are as familiar with these problems as we are.
