AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung 2011 Plasma Lineup
Samsung 2011 Plasma Lineup - Page 44
post #1291 of 3464
Any word on the 4K ( 1080p X 2 ) TV units, AVR and HDMI cable companies are starting to bring these spec products to market and are available now.
post #1292 of 3464
It will be YEARS and YEARS before any major content is produced with those specs. Movies, games etc...
post #1293 of 3464
Like 3d movies, TV shows and alike, sure there be a few to keep the lawyers at bay... Time will tell, how many times can I watch Shrek
post #1294 of 3464
Originally Posted by TitusTroy View Post
will look into it...honestly though I don't mind a 'cheap' stand as long as it looks good, has room enough to hold my large center channel and is sturdy enough to hold my equipment
http://www.mercantila.com/p/innovex-...arble-tv-stand
http://www.mercantila.com/p/innovex-bird-eye-tv-stand
These are (relatively) cheap and are wide enough to put a 64" TV on them with ~ 4" of shelf left on each side. There is also over 8" of space between the shelves, much more than most stands. I bought the black one and am very happy with it, you can even move it around with the TV and components on it if you're careful.
post #1295 of 3464
thanks...I like the one in the first link...looks a lot like my current 50" stand that I bought from Best Buy
post #1296 of 3464
I just stopped in at Fry's in Concord, CA this morning and the 51D7000 and 51D8000 are both on display, the D8000 paired with the QWERTY remote referenced in a previous post. I took some cell phone pics but they being displayed in a dark room so there's really not much to see. Unfortunately, posted prices are probably MSRP @ 19 and 23, respectively, with no mention of the 3D starter kit.
The silver bezel on the D8000 didn't look bad at all in the darkened room. I had to look closely to notice it and didn't really notice the difference between it and the flat black bezel on the D7000 (they were side-by-side). They would obviously look different in a lighted room, but I don't think the silver will be conspicuous while watching TV.
post #1297 of 3464
in some pics the D8000 looks more like a light gray color as opposed to silver...what color did it look to you up close?
post #1298 of 3464
How does the 7000 stack up against the Panasonic GT30? At least in regards to them both being the 2nd from the top and both seemingly sharing a lot of if not most of the quality/picture oriented feature of their bigger brother?
In other words, which one seems to be the better deal and which one comes closer to their top model version?
post #1299 of 3464
I'd describe it as something short of "brushed aluminum", but definitely not polished. It did reflect back the flash from my cell phone cam, but again, it was a very dark room so don't put too much stock in my impression.
If you want to see the 4 crappy pics of the D8000 I snapped, you can click my link to #1 then substitute 2, 3 and 4 in the URL to see the others.
http://goo.gl/zp1Ob
post #1300 of 3464
http://goo.gl/zp1Ob
the bezel actually doesn't look so bad in that pic although like you said that probably has more to do with the quality of the pic itself...the stand looks silver but the bezel color looks more like the C8000 in pic #1...I wish Samsung would have used the same color this year as on the C8000
post #1301 of 3464
Originally Posted by maygit View Post
I didn't hear a buzz, but i didn't listen for one either. Plus, with all the background noise in the store i doubt i would because i've tried to ever since the B850 and still have yet to hear a buzzer...it also probably does not help that i cant hear sounds over 14khz according to 3 sound apps on my ipod .
I'm not sure if it opened up the apps option, but if i were to guess i would say yes it did. I remember when i went to the "Network" settings in the menu when i was under the D6500/7000 mode there were 3 options available(i don't recall which), when i switched the tv back to the D550 only 2 options were available. Unfortunately, i'm not back in until wednesday evening, but maybe if i get a chance to stop in tomorrow i'll check it out. If not, look forward to a response on wednesday if no one else beats me to it.
Official look: No when service menu updated to D6500/7000, the apps are not available. The 3 options that come available under "Network Options" are: Network Settings, Network Status, and AllShare Settings
I also tried a D6450 model and it offered the same options as the D6500/7000 and one strange thing i noticed while i the mode was changed to the D570/6450/6500/7000 was that the touch panel sensor buttons no longer worked. Not that anyone uses the panel buttons over the remote control, but incase u do, they will not work if you upgrade the model through the service menu. I played around with some other stuff, but nothing else stood out except the amount of test patterns that were available in the service menu. Holy crap, they had a ton to play around with.
post #1302 of 3464
Not a big fan of the QWERTY remote....
post #1303 of 3464
The bezel doesn't look nearly as bad as I thought it would. The claw stand has got to go though.
post #1304 of 3464
Thanks for checking all that out!
Agreed, looks hideous. What were they thinking??
post #1305 of 3464
I was surprised to see it and not the touchscreen, but I played with it a bit and it's not so awful to use. Felt pretty natural in-hand because it is wedge shaped; not too big and not too small. Certainly better than the text entry Samsung and Sony have come up with on their DVD players I've used. The little LCD display is all about useless, though. Not backlit and whatever it says seems to be constantly scrolling sideways.
post #1306 of 3464
Here is the first review that I've found for a 2011 Samsung TV trustedreviews.com/tvs/review/2011/03/10/Samsung-UE55D8000/p1. It refers to LED-LCD version but might be interesting to read.
post #1307 of 3464
Newb here.
I was trying to buy a 2010 samsung dispaly model on the cheap at one of our local big box stores and I ended up getting a PN51D490 by mistake. I got it home and couldn't figure out why model number wasn't coming up in the 3D Glasses on various website until doing some research on your forums. Just playing around with it I love it. Nice picture, the USB port read my VOB files on my non internet media player so I do not need to bother having the media player connected to this tv. I'm still a novice when it comes to tvs but I'm enjoying this tv.
Haven't had a chance to buy the 3D Glasses yet as the samsung rep i talked to said they aren't widely available yet. Newb Question: Does it matter what 3D Bluray player i buy with it?
post #1308 of 3464
Thanks for the link. If led sets have a big reduction in ghosting, the plasma models should have it licked (hopefully).
post #1309 of 3464
Originally Posted by KCJAY18 View Post
Newb here.
depending on what floor model you were buying, may or may not be Christmas
post #1310 of 3464
well i just went and bought the PN59D550 from Vann's and got them to throw in the new starter kit for ... should be here by monday opps almost forgot no prices... well they gave me a smoking deal
463509808 Samsung PN59D550
776109058 Samsung SSGP3100M
Subtotal:
Shipping: $0.00
Tax Subtotal: $0.00
Grand Total: $
post #1311 of 3464
Subtotal:
Shipping: $0.00
Tax Subtotal: $0.00
Grand Total: $
You know what you need to do right? You need to tell us if the darn thing BUZZES!!!!!!!!!!!!!!!!!!!!!!!!
post #1312 of 3464
PN51D490 by mistake, they couldn't of given you a lower 3D model, but you could of paid for a higher model. You should check it out, in this scenario , you could only get what you paid for or less than you paid for.. You broke even or lost , and you couldn't win in this one. Are you free one night to play cards
Unless its a PN50C490, but they still are the same price, and its still floor unit or customer return.
Anyway enjoy your new TV
post #1313 of 3464
And tell me in a PM what you got the starter kit for. Also is this the starter kit with the Shrek movies and the aninmated movie with the bad blue guy and last which glasses did you get rechargeable or battery?
post #1314 of 3464
showing available at my local best buy.... bout to take a ride and check out the 59D550
post #1315 of 3464
I notice that none of the D models list the 1-tuner Picture in Picture that was available on the C models. I was thinking this was a nice feature, can anyone who owns a C tell me if the feature is any good or anyone with a D tell me if indeed the feature is available. Thanks.
post #1316 of 3464
if it buzzes i will sure post it... right after the wife get done kicking my %%%%.... i have a PN50B550 that she loves and really thinks we do not need a new tv... but i think the old 50 will be great for our bedroom.. it has a great picture
post #1317 of 3464
Amazon has the PN51D7000 in stock... My ship date is scheduled for the 14th
post #1318 of 3464
why not get the 59" D550 ?
we are talking about 8" !!!!!!!! and maybe the same PQ.
and the same price
it would be nice for a Pro Review..... only one so far by Chad
a Panny ST30 review...
I bet the D550 vs the ST30 will show the Samsung is the better of the two.
post #1319 of 3464
Does anyone know if the d7000 has the mjc or soap opera affect or whatever they call it like the c8000 had?
post #1320 of 3464
the D8000 looks pretty good. the panels ar filter looks good thanks for posting
