Hi,
can anybody on this thread share his "general" setup for a Radiance Mini for a given display ?
Specific questions that I have:
(1) What Output Color Format do you use ?
> manual recommends YCbCr 4:2:2 (if display supports it), others have mentioned that as well... How would one test if a YCbCr 4:4:4 output would be better for a given display ? I have a Panny VT50...
(2) What Dithering do you use ?
I t would appear that "Auto" is a good default setting, but I found in my testing that 8-bit output is better than any other option on my TV's...
> on my Sony KDS-R60XBR1 (RPTV, built 2006), "Auto" resembled the "8-bit" setting and was visually the best
> on the Panasonic TC-P65VT50 (Plasma, 2012), "Auto" resembled the "10-bit" setting, but 8-bit was the visually best setting
What are your experiences ?
I've tested visually using a grey scale, checking for smoothness... Is there a better way to determine a dithering setting ?
(3) Setup Prior To Calibration
** I edited this out, this question made was answered.
Thanks !
- M
Edited by Iron Mike - 12/13/12 at 1:24am
Thanks !
- M
I think when he said that was not a Null Modem cable, he was responding to my post where I linked the cable that was not a Null Modem cable, but maybe Axel can confirm this. I want to make sure I am buying the right cable here.
I have it set on game mode. Only thing I am using on the Mini is NLS.
