hrc4u:
The chips do connect to the case but through the PCB, and its power plane layers. The case does act as a heatsink both for heat conducted through the PCB, and for heat radiated from the chips to the 16 gauge steel top cover.
Adding heatsinks is not a bad idea nor is adding a fan. However, these should not be needed since the Mini is designed for convection cooling. Just make sure to have good ventilation around the Mini.
All signs point to this being fixed which makes me happy.
