AVS › AVS Forum › Video Components › Video Processors › Official Lumagen RadianceMini 3D thread.
Official Lumagen RadianceMini 3D thread. - Page 29
post #841 of 846
I ordered my Lumagen mini through AvS avscience just have to wait, to get everything set up when i get it can someone please tell me of a USB to serial adapter that will works with the lumagen mini and can it please be from amazon since i have amazon prime its easier for me to just order through there.
how will i be able to use the lumagen mini with calman 5 through the same USB to Serial adapter and also will i be able to update it by the same cable?
post #842 of 846
not in the US so can't comment on which amazon product to order. Can say that you should be able to use the same cable for all jobs
post #843 of 846
thanks, i all ready saw in the lumagen website how to update the lumen, but will a regular USB to serial adapter work? or do i need a specific type?
post #844 of 846
post #845 of 846
We have not tested this specific USB-to-serial adapter, so we can not be absolutely certain. What has been the determining factor for a USB to serial adapter has that it must be rated for the operating system you are using, and it needs to have the latest device driver from the vendor.
So this USB to serial should work.
post #846 of 846
Than
thanks for the reply. I'll post if it does work when I get the lumagen.
  Back to Forum: Video Processors
