Originally Posted by
3dPCH
In a Sharp I saw a disappointing amount of ghosting (for an active shutter glass system), but good 3D; on one LG (passive glasses) I saw no ghosting , but a noticeable problem rendering correct depth on parts of the display (same for the in-store demo video); I went to another LG and the depth rendered correctly, picture was great, some motion lines.
Ghosting derives from a not perfect separation of the Sharp or LG. Both, active and passive systems, are sensible for ghosting (at least I have seen on both systems more or less significant ghosting). The comparison of the Sharp and the LG for ghosting would be valid only, if it has been the same footage that you have seen. Without that I would not trust that.
The point is more, that the combination of high disparity AND high contrast makes the likelyhood for ghosting significant higher. You can influence contrast a little bit (not with your TD10 but in the postpro, or with high-sofisticated units like the Z10K by choosing another gamma curve). But what you can influence to avoid ghosting is the disparity you have in your videos. That is the major reason why I am a absolut fan of low disparities in our products (as good as possible).
3dPCH
Are we seeing the full resolution when displaying 3D video directly from the TD10 via the HDMI-out port into the TV, and if not, is it significant?
Yes, if you playback 3D footage from your TD10 via HDMI-out you will have 1080 60i if the HDTV is able to display that. Be aware that there are a lot of settings in your TD10 where you can adjust the output - for example to 1080 60i or 1080 60p or to lower resolution also. A lot of people like that, since here you are able to playback the native resolution where the camera shoots in.
My opinion is still, that there is not such a huge difference between 1080 50i and 720 50p (I shoot in PAL).
3dPCH
Are you losing any data by not using PMB 1st to download the raw video onto your computer before using a video editor (again, is it significant)?
No, since the PMB copies the footage only. Also, if you use Vegas or Vegas Moviestudio HD Platinum, you will not loose quality when coping the footage to the harddisc.
3dPCH
Are there any new software/editing options that make it easier to get TD10 video converted for Blu-Ray disc burning at a
resolution and frame rate and time investment that makes it worthwhile. (i.e., is it still for experts only?)
The issue is the 3D Blu-ray specification, that allows 720 50p, 720 60p and 1080 24p only. So since you come from a footage with 1080 60i, you always may need a conversion. At least for 3D Blu-ray. So a new software will not help really.
What is possible is that you use the PMB to create a BDAV structure on a Blu-ray. The newer Blu-ray player are able to playback the footage then with 1080 60i, some play that back as 720p only, and some do not playback that at all. I do not know any other software yet, that is able to create such a BDAV-structure for 3D.
3dPCH
Are there any particular 3D TV specs I should look for to maximize the quality of TD10 output with minimal editing?
If you wish to edit the footage, you have to use a software that has an MVC-encoder - to be able to create a Blu-ray. If that is minimum editing may depend on your definition. Minimum editing can be done also with the PMB - in terms of trimming clips and make cut-points. But no color correction, no level correction, no adjustment of the geometrics (but that is not often requiered for the TD10).
3dPCH
What is the easiest display method- using a computer hooked to the TV thru a video editor?; burn a DVD/Blu-Ray?; a mass media storage device that the TV recognizes?; HDMI-out from the camera? (apologies for the general nature of all these questions).
Comments (or not) on one or all of these topics appreciated.
To my opinion to burn a 3D Blu-ray accoding to the actual standards as defined by the Blu-ray consortia. And to playback that with a standard 3D Blu-ray player - or with a harddisk player like the Prodigy 3D or the iconbit.
But there is no general answer to that - this will depend on your wishes and needs. There is also some editing possibility in the TD10 itself - but be aware that edited footage in the TD10 cannot be edited again in Vegas (you loose 3D here, for whatever reason).
