AVS › AVS Forum › 3D Central › 3D Source Components › Sony HDR-TD10 3D-Capable Camcorder
Sony HDR-TD10 3D-Capable Camcorder - Page 52
post #1531 of 1532
Opening graphics looked good too. What did you use to create the cartoon effects?
You might want to pump up the sound track. Use Normalize in Vegas at first. I had to crank all my amps up to hear it.
post #1532 of 1532
Thanks Don, I'm a beginner with the audio, .... it sounded fine on my pc, so I had no idea it was so far off.
Would you try this other one http://www.youtube.com/watch?v=ugQFwVLW1g4 ... does it have the same problem?
I animate in lightwave 3d, wanted to get that old cartoon look. I'm going to try some tests animating the interaxial on the fly.
Do polarizing filters work with your modification?
Tony
Edited by tony3dd - 5/13/13 at 11:36am
  Back to Forum: 3D Source Components
