Originally Posted by Andrew_Woods
I can't speak for other users, but this was my reasoning:
1. Because downloading via PMB is VERY slow. My estimate is that it takes about 10 times longer to download the clips through PMB, than directly. (I must admit that I'm a little bit worried that PMB might be recompressing some aspect of the files).
2. Because it requires the installation of additional software.
3. Direct downloading has worked with every other camera I've used.
Direct downloading the <2GB MTS files seems to work perfectly - it's just the >2GB split files which cause the problem.
As Richard mentioned, the problem seems to be related to some bugs in Sony Vegas Movie Studio 11.
And, even after using PMB to download the clips, SVMS11 still won't correctly ingest files greater than 2GB, requiring extra acrobatics.
1. Compared to what? Something you did that doesn't work?
2. LOL! You are grasping for excuses. I'd bet with your trouble you have all sorts of unnecessary software on your system you installed.
3. Direct downloading of files on the camera that were saved in a format that works directly in Vegas. 3D is totally different.
Sorry, but Richard is looking in the wrong direction for the resolution to his problems with Vegas.
PMB created m2ts from the files on the TD10 are no problem working in VMS HD Platinum. v11 or v10. I loaded up a >12Gb m2ts file the last time I worked with VMS and it loaded fast and rendered about 50% longer time frame than Vegas Pro I'm thinking the extra time was due to 32 bit with 3Gb RAM restriction vs. 64bit Vegas Pro with 8Gb ram. Either way the computer did not crash and the operation was complete all the way through.
Go back to when Vegas first was released in v10d for 3D MVC video in mid May. I had lots of crashes, like everyone else with trouble here. But I went through and did some house cleaning and uninstalled all the bloatware I had including many of the experimental 3D apps recommended here. Then I cleaned up the fragments left in my registry file. There were lots left from all that bug beta wear I had installed. Two things happened after that. 1. My system rebooted in 15% of the time and 2. Vegas hasn't crashed since! It is now 100% crash free! I've done some pretty robust timelines with tons of slomo, pan crop, mattes keyframed effects, 4 and 5 layer 3D composites and the rendering and editing are all crash free. Besides, its running on a 64bit quadcore with Vista Home 64 bit. Vista the OS that everyone claims is so buggy yet you all are the ones with all the trouble.
Is Vegas ( both consumer and pro) perfect? No. Vegas Media Studio does have the clickity DD 5.1 artifact on TD10 clips but as they now fixed that bug in Vegas Pro 10e, I'm waiting for an update to VMS v11 to have an update to fix that too. But even with that bug, VMS v11 is quite stable and has none of the problems you and Richard are suggesting.The only bugs I have seen in Vegas Pro v10e are cosmetic and work flow issues in the burn bluray.
Unfortunately, there's no 60i 3D Blu-ray spec. I'd love it if there were. The MVC files from my JVC look absolutely stunning played back on a 3D TV. Buttery smooth motion and incredible detail, color and contrast. It's a shame we can't maintain that 3D image quality from the camcorder to a disc. I'm hoping we see an AVCHD-like extension to 3D Blu-ray, where that's possible. If an editor had only to render the effects, then do a smart copy of the rest of the original footage, we wouldn't have to settle for the processing loss of going to 1080p24 or 720p60 3D Blu-ray. If there's enough demand, the CE companies will make it happen.
It was also the last time I was able to take a trip with my Godfather, before he became too ill to travel, so it will always be a trip I remember very fondly.
