AVS › AVS Forum › HDTV › HDTV Technical › Considering a 47" Philips, model number 47PFL5704D. Pls help!
post #1 of 3
Hi,
Back to this forum after over a year of not logging in
Im currently considering buying the Philips HDTV model number 47PFL5704D at Walmart.
It is a 1080P, 120Hz, 47" HDTV with a 2ms response time. (For ~ $700.)
But under "video formats" it lists this in the specs...
•Aspect ratio: Widescreen
•Brightness: 500 cd/m²
•Dynamic screen contrast: 29000:1
•Response time (typical): 2 ms
•Viewing angle: 178º (H) / 178º (V)
•Diagonal screen size (inch): 47 inch
•Diagonal screen size (metric): 119 cm
•Visible screen diagonal (inch): 46.96 inch
•Panel resolution: 1920x1080p
•Picture enhancement: Pixel Plus 3 HD, 3/2 - 2/2 motion pull down, 3D Combfilter, Active Control + Light sensor, Dynamic contrast enhancement, Progressive Scan, 120Hz LCD, HD Natural Motion
•Computer formats: 640 x 480, 60Hz, 800 x 600, 60Hz, 1024 x 768, 60Hz, 1280 x 768, 60Hz, 1280 x 1024, 60Hz, 1360 x 768, 60Hz, 1920 x 1080, 60Hz
•Video formats: 480i, 60Hz, 480p, 60Hz, 720p, 60Hz, 1080i, 60Hz, 1080p, 60Hz
I'm confused... it says its a 120Hz TV on several websites... So why does each format say 60Hz next to it? I wanted to post the link, but I have less than 3 posts so I cant. But again, the model number is 47PFL5704D.
I intend to hook up my Xbox 360 with an HDMI cable... Im attracted to the TV for its 2ms response time, 1080P 120Hz capability... but is it really only 60Hz??
Can anyone confirm this for me before I give Walmart my $700?
Thanks everyone!!
post #2 of 3
Welcome back, best bet is to post this under the LCD Flat Panel section under Display Devices.
post #3 of 3
shoot my bad, ill post over there, tks!... maybe a MOD cant delete this thread..
  Back to Forum: HDTV Technical
