Sony Press Release:
Driving Picture Quality
From full HD 1080p Blu-ray Disc, to broadcast HD, to user-generated Internet Video content, processing of incoming content is essential for an excellent picture. To this end, Sony has upgraded the BRAVIA processing power with the new X-Reality PRO and X-Reality Engine digital video processors.
The X-Reality PRO Engine is a two-chip digital video processor that optimizes high definition content, compressed HD signals, standard definition, and other sources including low resolution Internet content. Utilizing a vast database of "ideal" signal patterns developed by analyzing and indexing and enormous library of film and video, the X-Reality PRO Engine compares incoming signals pixel-by-pixel with ideal scenes to display vivid and detailed images.
Additionally, the engine's multi-frame analysis helps create missing resolution and Sony's Super Bit Mapping technology incorporates 14 bit up-scaling, processing and pixel mapping to smooth gradation and improve the quality of low-tone pictures.
Found in select models, the single chip X-Reality Engine utilizes Sony's Intelligent Image Enhancer technology to deliver outstanding picture quality. Incoming video is separated into constituent parts (outline, texture, and color/contrast), and the appropriate image enhancement is added to each part. The engine also uses Intelligent MPEG Noise Reduction to automatically detect the incoming sources and noise level to apply the appropriate amount of noise reduction for each scene.
Also new for select models is Sony's Intelligent Peak LED Backlight which uses full array local dimming for deeper blacks, while also boosting brightness in lighter scenes creating incredible on-screen contrast, while Sony's OptiContrast panel elevates the picture to the front surface of the TV and creates a dark background for rich, vibrant, high contrast picture even in well-lit rooms.
Sony's MotionFlowâ„¢ XR builds on previous versions of the company's motion compensation technology and helps to reduce blur caused by quick camera movements, enhancing sharpness and creating a clearer picture.
Simplifying User Interface and Functionality
Select new BRAVIA models feature Sony's improved user interface that delivers uninterrupted viewing and intuitive navigation. Retaining the intuitive operation of the award-winning Xross Media Bar (XMBâ„¢), the new UI provides uninterrupted viewing by disseminating the video and placing key menu functions and favorite along the bottom and side of the picture frame.
Additionally, the models feature an improved remote control and offer control via the Media Remote application on iPhone, iPod Touch or Android mobile device. The app, which can be downloaded from the Apple App Store or the Android Marketplace, functions as a full remote with keyboard, allows online content search, and playback.
BRAVIA XBR-HX929 Series 3D Capable HDTV
Available in April, Sony's new 3D capable (with the addition of Sony active shutter glasses, sold separately), XBR-HX929 series features brilliant full HD (1080p) picture quality with Sony's Intelligent Peak LED backlight for outstanding contrast.
The model also features Sony's MotionFlow XR 960 featuring a precise backlight control that is synchronized with the liquid crystal movement from frame to frame creating clearer, sharper moving images.
The beautifully designed model features Sony's improved Monolithic Design Concept that draws viewers into the picture when the TV is turned on, and blends into the room décor when turned off. The 2011 Monolithic Design BRAVIA models incorporate Corning®'s Gorilla® Glass allowing for thinner, lighter, and stronger screen material.
With integrated with Wi-Fi (802.11n), the XBR-HX929 models offer instant access to thousands of Internet movies, videos and music from BRAVIA Internet Video and Qriocity. Sony's Media Remote app provides simple operation and search for internet content.
The XBR-HX929 models are also custom installation friendly with key features such as rear IR-input and a two-way RS232c connection for easier integration with third-party control systems.
Other XBR-HX929 Series features include:
Brilliant Full HD (1080p) picture quality with full-array local dimming LED backlight
Sleek Monolithic Design with OptiContrast Panel Technology
Integrated Wi-Fi (802.11n)
Skypeâ„¢ ready in 720p high definition
X-Realityâ„¢ PRO Engine
MotionFlowâ„¢ XR 960
Rear two-way IR inputs and two-way RS232C control
Screen sizes include 65-inch (XBR-65HX292, which is available in August 2011),
