AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › LG HW300T LED 1280x800
post #1 of 695
Texas Instruments has released a new HD chipset according to reports from CES 2011
LG: "It is exciting to work together with DLP and their new HD chipset," said YE Kim, Projector Business Team Leader, LG Electronics. "With our new HW300T multimedia pocket projector with built-in TV tuner, we expect to maintain our leadership position through improvements in resolution and brightness, and a form factor that will best serve both the portable business and consumer entertainment environments."
In accordance with this new HD chipset LG is releasing the HW300T:
LG’s new portable projector, the HW300T, is a veritable treasure trove of multimedia functionality. This LED-powered light-thrower comes with DLNA, ATSC and Wi-Fi.
DLNA means it can share content over your home network. So videos and photos on your PC can be wirelessly beamed to the HW300T, then projected onto your wall.
The ATSC television tuner is essentially a terrestrial digital HDTV tuner, built directly into the projector. But don’t get too excited just yet: ATSC is only currently available in Central America, North America and LG’s native South Korea.
Also on board is a broadband function allowing access to web-connected services including Twitter, Facebook and Accuweather.
On the spec front, the LG HW300T has a 1280 x 800 resolution, 250 ANSI lumens brightness, 2,000:1 contrast ratio and HDMI socket.
*Info and picture courtesy of Techradar.com and Texas Instruments
post #2 of 695
With the HX300 being 270 Lumens, why has the higher resolution HW300T taken a hit down to 250 Lumens?
Would a higher resolution, lower lumen projector interest those of us who bought the HX300 last year?
Personally I'm a little disappointed by this announcement, I was hoping for at least 300 lumens to match the HX350Y!
post #3 of 695
Built in tuner is cool, price point is the problem with lg.
500 and they have a cool device.
post #4 of 695
this looks good but im much more interested in the Vivetek Qumi that was also announced it's a 1280x800 300 lumen led dlp with 3d support. http://www.projectorcentral.com/news_story_1552.htm
post #5 of 695
Well, just as i imagined : Lg launches a replacement for the 300 series using the same LED chipset from Luminus Devices to illuminate a 1200x800 DMD chip from Texas Instruments, around Summer 2011.
Instead of going full steam ahead and use a 1920x1080 chip mated to a more powerful chipset from Luminus Devices inside a bigger pj case, LG decided to take the easier route by introducing this evolutionary pj in its roster of presentation LED projectors; Too bad...
I don't think i'll bother selling my HX300G to get this one, as i did previously with the HS-201, considering that the HW300T puts out the same amount of lumens with a slight increase in pixel resolution.
Maybe by Summer 2012 LG will "get it" and give us what we're all waiting for and at such time frame such pj would perhaps be available for a msrp of $2.000/$2.500 ???
post #6 of 695
If they can solve the two major issues with picos, I'll gladly upgrade. Fan noise and focus are huge issues. Typically picos are near the viewers so any fan noise is in your face. Also picos need flexible focus as they are not fixed in place. Lumens are no longer the biggest issue. Qumi's 3D support is a major plus.
post #7 of 695
Uhm, perhaps i should ammend my post above.
After thinking more carefully about the 1200x800 pixel resolution of this new DLP chip from TI i realized that even though they call it WXGA it doesn't really fit the standard description of 1280x800, which is unusual.
I wonder how this resolution of the LGHW300T would look like being displayed natively on 4:3 screens and 16:9 screens.
VGA : 640x480 - 4:3 ratio
SVGA : 800x600 - 4:3
XGA : 1024x768 - 4:3
LG HW300T : 1200x800 - ???
HD STANDARD : 1280x720 - 16:9
WXGA : 1280x800 - 16:10
SXGA- : 1280x960 - 4:3
SXGA : 1280x1024 - 5:4
WSXGA : 1440x900 - 16:10
UXGA : 1600x1200 - 4:3
WSXGA+ : 1680x1050 - 16:10
HD STANDARD : 1920x1080 - 16:9
WUXGA : 1920x1200 - 16:10
post #8 of 695
There must be some confusion as to the actual resolution of these new DLP chips. The TI web site specifically states that the chips are WXGA. I have seen three different resolutions reported for the same chip, one 1280x768, two 1280x800, and three 1200x800. I'm sure there isn't three different chips, so two of these are wrong.
post #9 of 695
Do you mean zoom?I think you do, and I agree with all your points,That said the layouts of this new crop seem to be a lil bigger if they have a power brick meaning they can have larger lazyer fans.
post #10 of 695
chane2k1
Thank You very much for posting this, I just found my next projector, Hopefully it comes out on the predicted date
There are a hand full of options I won't use (have a HTPC so content delivered/stored on PC is already there (via HDMI)/ have an awesome over air HDTV USB stick that works great).
A 1280X800 projector that has 2500:1 contrast and 300 lumen (remember I'm still using the HS200 in normal mode with a De-lite High power screen and am VERY happy) sounds like this is the next step I will be making.
Vivetek is (and correct me if I am wrong) a rather good company and @ $500 (same as the HS 200) this sounds GREAT (to me).
AFM
post #11 of 695
Projector Central has posted specs for the HW300T and lists the resolution as WXGA 1280x800, 16:10 aspect ratio.
So, it appears that TI has released a brand new DMD chip optimized for pico/mini/portable/presentation/video applications; the chipset is HD ready and capable of displaying native 1080p content scaled to its native resolution with excellent results, i'd imagine.
Why the somewhat unusual pixel count and aspect ratio ? Perhaps something to do with the way the Windows display bar at the bottom of the screen displays better than on a 1280x720 screen with a 16:9 aspect ratio, just like on some laptops ?
All i know is that the more i read about this DMD HD-chipset being used on this upcoming LG pj, the more i am tempted to replace my HX300G for it....Here we go again, but at these price points of $500~$1.000, they're still affordable !
BTW, considering that Vivitek has already announced the msrp for the above posted Qumi LED pj, a direct competitor for the HW300T if there's one out there, perhaps that would force LG's hands to keep the pricing for the HW300T at similar levels ?
post #12 of 695
http://www.pcmag.com/encyclopedia_te...i=54923,00.asp
This isn't 1200x800. LG obviously made a typo, you guys are reading waaaaaay to much into this.
post #13 of 695
Yes, I have found that pcmag.com is a fairly unreliable source for technical specs. In another CES article they claimed that Mitsubishi laserview did not use DLP.
post #14 of 695
It's their encyclopedia dude.
http://en.wikipedia.org/wiki/Graphic...80.C3.97768.29
Is that a better link?
I can almost assure you it is not 1200x800. Somebody at LG forgot to put an 8 in there.
post #15 of 695
Wasn't there another manufacturer besides LG that also stated a 1200x800 resolution?
post #16 of 695
Man maybe but I doubt TI would screw up that bad and even bother making a 1200 pixel chip. It just doesn't make sense. I would assume it's 1280 with 98% certainty.
iPhone.
post #17 of 695
That this will be any where near 500$ is laughable-but it does have a lot of stuff packed in there ,that tuner and the web connectivity(we all needs our Twitter, Facebook and Accuweather ) should bump it in to the 1200$ range
post #18 of 695
any idea when the Vivitek and LG products will hit the shelves? I would like to see a comparison between he two before i make my pick.
One thing is certain though..life is getting better if they keep it up this way we'll see 1080p LED 3D projectors in year or two.
post #19 of 695
4 months for the qumi(who thought up that name,it must be an acronym)
post #20 of 695
Too dim... good luck with that.
post #21 of 695
This projector does not have a zoom capability, correct?
post #22 of 695
You can buy 1080p LED 3D projectors right now, if you can afford one. They start at around $15,000.
post #23 of 695
ORLY.. who is selling one?
post #24 of 695
Sorry, got two projectors mixed up, the Runco D-73D is $50,000 and is 1080p 3D LED. The other I was thinking of is the LG CF3D, which is 1080p 3D, but not LED as I thought.
post #25 of 695
TruVue Vango and Color Processor Bundle
On sale:
$10,999.00
http://shop.avscience.com/TruVue-Van...ndle_p_29.html
there are two others I think in the 10,000-15,000ish range
post #26 of 695
Right, and you are basically spending 50,000 dollars on 2 projectors and runco still doesn't recommend over a 100 inch screen(what's the point, mitsu has 92inch dlp now)
Short of going polarized passive 3d with dual projectors, i just don't see it happening for LED in the near future. One day maybe, but right now they just aren't bright enough.
post #27 of 695
On sale:
$10,999.00
The Vango was very-well reviewed by Home Theater Magazine as were the other expensive LED offerings; Some turned out to be brighter than the others but all fell between 15 to 20 ft-L after calibration on screens sized from 92" to 106" diagonal, figures that are comparable to standard bulb projectors, again, after calibration.
The problem i see with very/very expensive products from a company such as this one, Vango, is what are the chances that it will be around three years from now in case of parts/repairs after the customer spends that amount of money ?
post #28 of 695
Unfortunately I misplaced my $10,000 budget for a projector
post #29 of 695
Well we get tired of "Gee I cant wait for a 1080 p led...."same with 720p led its been around for a while now.The fanbois wont shell out 900$ for 720p at 250 lum., the qumi will save them>I am shocked that 1024x768 lgs sold at 700$
post #30 of 695
I could have sworn people on here were paying 800... which is completely nuts. You could have gotten a real 720p, bright bulb projector and a spare bulb for that price.
