I have installed the Monoprice Adjustable Tilting/Swiveling Wall Mount Bracket (ID 6516) into the wall. Once I hung the LCD on it I heard noise at the attachment point. It sounded like the metal scraping down the threads of the screws that are in the back of the mount. Please check the images and let me know if this looks right.
It just seems that the screws are VERY loose on the top portion. Should they be?
