AIRPLAY QUICK PLAY:
1) Do the AirPlay upgrade.
2) Do a Denon version retrieve (standby+status+return)
3) Start iTunes, select receiver in Airplay icon (bottom right) icon must be blue: play music.
4) Select iPad, REMOTE APP play music.
__________________
take note: airplay hijacks the main zone of the AVR:and limits the video processor ; all main and zones default to NET/USB to support airplay: so there is no independent zone out of airplay. Also, the video processor is limited: only video is now playing screens
here are some troubleshooting tips not in any particular order: please feel free to suggest additions/ edits to this primer [my tips are based on Denon AVR-A100 and Mac OS X]
Setup
--first you must purchase Airplay from the Denon site http://shop.denon.com/Airplay-Upgrade-W4.aspx there is a link on the page to download the 4 page upgrade manual (click on your model number first)
perform the AVR firmware upgrade et al : there is a 4 page pdf on the Denon site that details this: be sure when you enter the upgrade ID that you do not confuse zeroes and o's
--check you have latest version of iTunes & iPad firmware
--check app store for any updates for REMOTE app
Troubleshooting:
--error 15006: see this link: http://www.avsforum.com/avs-vb/showt...5#post19776555
-- airplay hijacks the main zone of the AVR: all main and zones default to NET/USB to support airplay: so there is no independent zone out of airplay
--power cycle the Denon (remove AC plug)
--reboot computer: reboot router to ensure network connection
--go to iTunes bottom right icon that says multiple speakers (airplay icon): it should be blue. click on it and be sure the Denon AVR is listed and a check mark appears showing it is selected: if not double click on it to force a connect: Denon CS says it may take several tries
--go into Denon menu/ network/ other and be sure network standby is ON
--on Denon front panel, hold return and left arrow for 3 seconds: display should confirm no updates needed.you can also check in menu manual setup, option 3, add new feature
-- restarting airplay: toggle the airplay icon in iTunes from the AVR to PC or some other input, then back again to restart
Firmware update fails and unit keeps trying to upgrade:
--disconnect any third party control system from the RS232 port before attempting a firmware push
--after a reset, go quickly into menu/manual setup/option 3 and turn off firmware & upgrade notification [Network Setup/Upgrade Notification = Off]
--try to connect Ethernet direct to router (reboot it after connecting) to see if that works for the update rather than going through a switch
-- reports of the Denon appearing with and extra identifier and throwing an error on selection. I had that problem with an iTunes instance that was already running. I restarted that iTunes, selected the 4311, played music. It was all quite easy and painless iTunes run on Macs.
--if necessary, do a network/microprocessor reset: you may lose all your settings if not saved
I don't want Airplay or its firmware update: go into menu/manual setup/option 3 and turn off upgrade notification [Network Setup/Upgrade Notification = Off
To start Airplay: go to the iPad REMOTE app: it should show your iTunes library: select your song or radio to start playing: it may automatically change the Denon input to NET/USB [or set it manually to NET/USB] and airplay should start
[b]
From Apple site:general Airplay info
Troubleshooting AirPlay
If your Apple TV, Airport Express, or compatible 3rd-party device does not appear in the AirPlay menu, follow these steps to resolve the issue:
1. Verify that your AirPlay-enabled devices have the most up-to-date software or firmware (see the table above for minimum AirPlay requirements).
2. Verify that all your AirPlay-enabled devices are on the same network.
3. Verify that your iOS device has Wi-Fi turned on and is associated with the same network as your AirPlay-enabled device.
4. Ensure that AirPlay is enabled on the device to which you are trying to stream content (for example, you can disable or enable AirPlay on Apple TV in the AirPlay menu: Settings > AirPlay).
5. Check Internet or network connectivity on all affected devices.
6. Temporarily disable firewalls (both network and local) and security software. Security software and firewalls may block ports that AirPlay uses to stream content. You can often resolve issues with security software by updating, correctly configuring, or uninstalling security software.
7. Ensure that other devices are not trying to stream to the same AirPlay-enabled device at the same time.
8. Turn off Bluetooth on your iOS device by tapping Settings > General > Bluetooth
http://support.apple.com/kb/HT4437
How to Configure the Apple iTunes REMOTE APP
http://www.youtube.com/watch?v=a_hIlFBKZ_A
How to Enable iTunes in Windows XP/Vista/7 Firewall
WINDOWS XP
When the firewall in Windows XP is enabled, it may prevent iTunes from accessing the Internet unless iTunes is listed as an exception.
To make sure that your firewall is not blocking iTunes:
1. On the Start menu, click Control Panel
2. Double-click Internet Connections
3. Right-click the network interface you use for Internet access and from the shortcut menu choose Properties.
4. In the Properties window, click the Advanced tab.
5. In the Windows Firewall section, click the Settings button.
6. In the Windows Firewall window, make sure that the "Don't allow exceptions" option is not selected, and then click the Exceptions tab.
7. Make sure that iTunes is checked under "Programs and Services" and click OK. If iTunes isn't listed under Programs and Services, click Add Program. If iTunes isn't listed in the Programs list, click Browse, navigate to the iTunes program (often at C:\\\\Program Files\\\\iTunes\\\\iTunes), select it and click Open. Note that iTunes may also appear as "iTunes.exe."
8. Click OK in the "Add a Program" window.
9. Click OK in the "Windows Firewall" windows.
10. Click OK in the Properties window.
WINDOWS VISTA
1. From the Start menu, choose Control Panel.
2. Click Security and click Windows Firewall.
Note: in the Classic View of Control Panel, click Windows Firewall.
3. Click Change Settings.
4. If Windows needs your permission to continue, click Continue.
5. In the Windows Firewall Settings window, make sure that the "Block all incoming connections" option is not selected, and then click the Exceptions tab.
To make sure that iTunes appears in your list of programs:
1. Make sure that iTunes is checked under "Programs or port" and click OK.
2. If iTunes isn't listed under Programs and Services, click Add Program, click Browse and navigate to the iTunes program (often at C:\\Program Files\\iTunes\\iTunes).
Note: For 64 bit editions of Windows navigate to C:\\Program Files (x86)\\iTunes\\iTunes.
3. Select iTunes program and click Open.
Note: iTunes may also appear as "iTunes.exe."
4. Click OK in the "Add a Program" window.
5. Click OK in the "Windows Firewall Settings" window.
6. Click OK in the Properties window.
WINDOWS 7
2. Click System and Security and click Windows Firewall.
Note: in the Icons View of Control Panel, click Windows Firewall.
3. Click "Allow a program or feature through Windows Firewall."
4. In the "Allowed Programs and Features" window, choose Change Settings.
5. Make sure that iTunes is checked for your network in use.
6. If iTunes isn't listed, click "Allow another program", click Browse, and navigate to the iTunes program (Usually in C:\\Program Files\\iTunes\\iTunes).
Note: For 64-bit editions of Windows, navigate to C:\\Program Files (x86)\\iTunes\\iTunes.
7. Select iTunes and click Open.
8. Click Add in the "Add a Program" window.
9. Click OK in the Allowed Programs window.
10. Close the Windows Firewall window.
Useful Apple/AirPlay links:
Apple iTunes 10: About playing music with AirPlay
http://support.apple.com/kb/HT4325[/quote]
caution: airplay hijacks the main zone of the AVR: all main and zones default to NET/USB to support airplay: so there is no independent zone out of airplay
If you decide Airplay is not for you: check out the Apple TV2
http://www.avsforum.com/avs-vb/showt...1#post19800191
__________________
Setup
Troubleshooting:
[b]
WINDOWS XP
WINDOWS VISTA
WINDOWS 7
