AVS › AVS Forum › 3D Central › 3D Source Components › JVC GS-TD1 3D-Capable Camcorder
JVC GS-TD1 3D-Capable Camcorder - Page 66
post #1951 of 2065
Originally Posted by steveclv View Post
I didn't buy the Magix software yet - just the trial version - but it pulls the AVCHD 3D footage in from the TD1 SD card just fine.
I'm in between Edius or Magix at the moment. Edius seems to be a little easier to get my head around smile.gif
Good luck burning a disc - I'm getting error #5 and there are a lot of Google hits for that error. The program reports that I don't have enough store space. Considering I have over 100GB free on the rendering drive and 150GB free on the boot SSD, that seems hard to believe. So, I'm trying to track down the reason for this error while I'm rendering with PD11 (made the jump from PD10).
The other funny thing was that I got an email back from DVDLogic regarding their EasyBD software. They essentially said that they don't have any 3D capabilities at this time but I could always use DoStudio or Scenarist to compile the menus. If I had those, of course, I wouldn't have needed EasyBD, but it was nice that they responded back.
I'm finding that Edius Pro has one giant advantage to it - it's stable and well programmed. Wish the others were as good.
Edited by alk3997 - 11/10/12 at 3:27pm
post #1952 of 2065
After a frustrating Saturday afternoon of video programs hanging and giving strange errors, I decided to try an experiment. I installed a dual-boot of Windows 7 32-bit and Windows 7 64-bit. So far the results are encoraging with PD11 actually fully creating a 3D menu structure (which it would not do with the Canopus files on the 32-bit side - terminated at 20% progress with 32-bit W7).
I'm slowing going through the programs to see which ones I can transfer to the 64-bit side. Some of the drivers I know will prevent me transferring their associated programs but hopefully the amount remaining in the 32-bit world will be small.
I'm going to work on Magix Pro X4 next.
post #1953 of 2065
So far I have tried Edius 6.5, Magix Video Pro X4, PowerDirector 11 and Vegas Pro 12 and continue to test them but so far none have been 100% successful.
PD11 has a nice interface but only recognises 2 out of 600 imports from my TD1 as being 3D - sees them as AVCHD but only as 2D - I don't know why it decided that 2 of them were 3D.
I like the program but when I came to create a test 3D file, it failed saying "Production unsuccessful" and that the video driver was out of date (it isn't and it's a Windows8 with Media Center laptop). It also hangs waiting for things to happen quite a lot despite my i7 processor so I think it's quite hardware demanding as a program.
I'm still erring towards Edius but I am going to give Magix more of a try over the next few days.
I did read (maybe here) that the AVCHD 2.0 3D standard is not (ever) intended for BluRay but only for SD cards - so are we expecting too much to be able to burn full resolution 3D movies to disk?
post #1954 of 2065
For MVC, both PD11 and Magix successfully created an iso. I burned the Magix this morning but have not had time to look at it yet (this evening, hopefully). I'll then take a look at the PD11 burn.
With Win 7-64, I've been pleased with the stability of PD11 and Magix for rendering the Canopus 3D files out of Edius.
post #1955 of 2065
For me that works fine. See the AVCHD 3D thread.
post #1956 of 2065
Thanks for keeping everyone updated on the results you're getting, guys.
To recap:
My Sony players (480 and 590) don't have a problem playing back AVCHD 3D from disc (DVD or Blu-ray), even at the higher data rate. Those videos were originally rendered to SD card in Edius (as AVCHD 3D folders with the AVCHD 3D Writer export option), then burned straight to disc with ImgBurn. My Epson projector down-converts the 3D to low resolution, but my LG passive 3D TV displays it just like it does other Full HD 3D. The Panasonic 320 player won't play AVCHD 3D folders burned to DVD. Other equipment combinations will likely yield similarly inconsistent results with AVCHD 3D.
IMO, Edius is the editor of choice for JVC users. It's stable and 3D playback is smoother than anything else I've used (at any price). Playback is much better than Vegas Pro 12 or PowerDirector. This is a huge factor when editing 3D. I'm using a Core i7 3930 OCed, with a middle of the road nVidia card (2GB GeForce 560, about $200). The drawback with Edius, of course, is that it won't let you burn a 3D disc directly, so you still have to go through other software to do that. The exception to that rule now is Grass Valley's addition of AVCHD 3D Writer option for SD output. Although it's basically without menus, it lets you use Edius/ImgBurn to burn to SD card, then put that on a disc. With the right combination of hardware, this allows you to get high quality Full HD 3D results with 60i material. Render times, however, are very, very long.
I still think converting to 1280x720/60p is the best choice for many projects. I use it for family events when very high resolution isn't necessary but smooth motion is. And it plays on any 3D player. PowerDirector will let you do this for JVC mp4 files, but not AVCHD 3D. Hopefully, Cyberlink will add support for JVC AVCHD 3D files, too, but it's far from guaranteed.
The only software that allow you to create higher quality output (original, in fact) is MediaBrowser, the free software that JVC provides to purchasers of the TD1/HMZ1. Footage is maintained in the original quality, but you have virtually no editing tools to work with. Still, for very simple editing and playback, this option is fastest and maintains the best quality. For everything but fades and title overlays, the footage is identical to the original.
post #1957 of 2065
I've been learning PowerDirector 11, the way I should have learned PD10. You can manipulate the bitrate with 3D MVC files. You have to create a custom template under the "Produce" tab. Then when you create your image under the "Disc" tab, PD11 will use the selection you made. I'm confirming that with a test burn right now. Earlier I had left "Produce" as 2D and ended up with a disc with 3D menus and 2D content. That was
"different" since the content wouldn't play (probably still had something set to 3D on the 2D files).
Also there are ways to make more-custom 3D menus. You can find out more at:
http://www.youtube.com/watch?v=E9ZU40cJvJ0
Skip over the commercial at the beginning.
Hopefully the 3D content will look as good as Vegas Pro's output (I hate to give them a plug) with the ABR set to 25mbps.
post #1958 of 2065
My issue with Edius 6.5 at the moment is the user interface - I don't know whether it's the font or the excessive use of icons but something is really annoying me about it - especially having compared it to the other 4 or 5 NLEs recently. I'm also thinking of building a new desktop dedicated to NLE - the laptop doesn't seem to handle any of them that well.
post #1959 of 2065
So I emailed JVC about the right lens being out of focus, and they don't seem to grasp what I am telling them. WHY is that? They emailed me a screenshot of how it should look. They were playing back a video using windows media player and it's a shot of Franks R2D3!!!! LOL and the BEST PART.. the RIGHT image is SOFT!!!! eek.gifmad.gif Has ANYONE gotten this successfully repaired????
post #1960 of 2065
Edius is certainly different than Vegas or Premiere and takes some getting used to, but in the end I've grown to like it a lot. I love that I'm able to double click the program monitor and go immediately into full screen preview mode, then double click to get back to editing. I use that one simple feature all the time.
My experience last year was that 3D editing brought my most powerful computer to its knees. I think you're right to consider a fast desktop. Laptops typically lack the raw muscle and hard drive speed. There are too many bottlenecks. Consider SSDs for the OS (no less than 120GB and preferrably 240+) and editing drives. I use a 3TB traditional HDD for mass storage and sometimes rendering. The price of SSDs has really fallen - by some 5-6x for some of them from a year or so ago. It's easy to find great deals at Tiger, Newegg and Micro Center.
post #1961 of 2065
How did it go? Thanks for the links. If you get a really good workflow going, be sure to post it.
post #1962 of 2065
It's interesting with PD11. The more I read the tutorial, the more options become available. The one fairly rigid thing seems to be the number of menus in the menu structure. But, the number of items on each menu is fairly flexible. 3D really is just an extension of the 2D work (but two options have to be enabled for 3D).
I think I accidentally encoded the original Canopus files onto the disc, which I didn't think was possible. So, I'm redo'ing the disc again. Whatever I encoded, the projector sure didn't understand. I had a good 3D menu and then playing the main title resulted in the no-signal blue screen with a non-recognized format indicated.
I'm comfortable that I'll have a good menu-based 3D creation when I'm done. It's a question of how good? The same with the audio - I believe I can get DTS 5.1 (not as good as LPCM but much better than Dolby Digital) when I'm done but haven't quite gotten there yet.
It's a good after work project and I'll make sure to append a more detailed workflow once I have it confirmed as working.
BTW, Wolfgang and you were absolutely right in how much of an improvement using the 64-bit O/S would be. It just took me a while to figure out that a dual boot setup would solve my 32-bit headache. Helps to have 8GB of memory, too.
post #1963 of 2065
I got this update from CyberLink today on my request for a fix to the problem of Power Director not working with AVCHD 3d from the JVCTD1. It looks like we are at least to 1st base now.
"1. For PowerDirector 11 Issue : For issue that PowerDirector unable to detect JVC GS-TD1 3D footage as 3D video issue, we have managed to reproduce this, and its now queued for analysis, so hopefully we will find a solution and see if we can support this format in future release."
post #1964 of 2065
That's great. Here's hoping they do.
post #1965 of 2065
If it helps, I added 600 TD1 AVCHD 3D tracks to PD11 and it saw them all as 2D except for 2 which it decided were 3D - if Cyberlink want them to see if it helps track down the problem then they can have them.
post #1966 of 2065
Thanks Stevecle,
If they start having problems, I'll let them know and see if we can get one of your working files to them.
post #1967 of 2065
I just want them to support the JVC .mp4 files... I import them into Cyberlink and they show as 3D just fine. But making a 3D disc and playing it shows the picture all disorted and messed up.
post #1968 of 2065
x 2.
Why half support the format, c'mon Cyberlink give us JVC users some love smile.gif On the positive side they were very professional and timely in giving me a full refund of PD11. I'll be keeping an eye on it though so if any updates come through guys please let us know. Specifically looking at improvements in the 1080/60i 3d render/playback workflow. I'll happily buy the software again if they manage to address this issue...oh and also it would be nice if ColorDirector supported 3D files.
post #1969 of 2065
I'm still coming up with incompatible video with the high MVC video rates. So, I've made some small (5 minute) test videos I'm going to try to use to debug. I've got 3D menus now. I used to have 3D video. Now, if I can just combine the two onto one disc...
post #1970 of 2065
alk, you mentioned if you go under "Produce" you can change the bitrate and then click on "Dic" and make the file or burn to disc. I have tried and made a custom template, but the only selection I get under disc is the 1080p 24p or 720
Even though it says that is it really burning the file with my custom presets?! I have tried a few and all look the same.
JVC's .mp4 files imported work fine but when burned are all messed up which is weird. I have to convert them with Edius which sucks just to get them looking alright on PD11:mad:
If Cyberlink can make it accept JVC files, .mp4 and AVCHD in high quality with different bitrates and options they will have many happy customers including me!
post #1971 of 2065
Sorry if I am going over previously discussed topics but where are we up to with Sony Vegas Pro 12 and JVC AVCHD 3D footage
I seem to be importing OK but it's not showing the footage as 3D but I can change it's properties to Stereoscopic Line Alternate but it's not immediately obvious that it is seeing it as 3D.
When I look at the Export or Burn to BD menus' I don't see a AVCHD 3D format
post #1972 of 2065
The anwer is simple:
- the TD1 footage can be imported in Vegas, but it is shown as 2D footage only. The only way would be to convert the footage to two streams, import it and pair the streams again. Do not ask me what tools could be used to do that - for the professional version they deliver a tool, if you have access to Edius it could be done wih the AVCHD2HQ converter. Or one could use the MVC to avi converter too.
- there is no possibility to render s3D footage in Vegas to an AVCHD 3D output - what would mean that you can render a multistream AVC file. That is not foreseen in Vegas, since Vegas delivers an MVC-encoder that allows you to render MVC-based 3D-Blu-rays. That can be done to an output with 720 50p/60p or 1080 24p only, what is some disadvantage since you come from 1080 60i/50i with the TD1.
post #1973 of 2065
You can use PowerDirector to convert JVC TD1 mp4's (but not AVCHD 3D files) into 3D m2ts files that Vegas can edit. It's a fairly tedious process, in that you need to do them one at a time, but the quality remains high while the file size stays about the same. I outlined the workflow earlier in the thread. Sorry, can't recall how far back, but it's been a while.
post #1974 of 2065
I think it might be a good idea if we all started tickets with CyberLink, as I have done, and express our concerns and desires. I think we will have to be persistent and stay on them, but if we do, I have some optimism that we will get the updates we want. I have a few open tickets with them right now on some of these issues and would strongly encourage all of you to do likewise. The one thing I haven't addressed with them is the issue you are alluding to about Power Director produced mp4s looking messed up when burned to disc. I have some which I have produced- but not burned- and they look OK. I have requested that they allow these mp4s to be produced at the same 34 bitrate. I also have a ticket on the AVCHD 3d issue, and one on the Power DVD 24p 3d playback limitation. I've also pressed them to allow Power Direct 11 to be able to burn the mp4 files at 1920 at their native frame rate rather than only 24p.
I really believe that if they hear about these limitations from many voices at the same time, it might have a positive effect. At the moment, they have 2 files, which they requested, and I uploaded to them. One is an mp4 and the other a AVCHD 3d file. I started this process last week and, now that they are believers, am getting feedback from them.
post #1975 of 2065
Good idea, Barry. The stronger the voice, the better the chances. I'll submit a ticket with them tonight on the PDVD 60i playback issue, followed closely by the PowerDirector 11 inability to recognize JVC AVCHD 3D.
post #1976 of 2065
Success! - I finally have a 3D menu-based MVC Blu-Ray disc. The video to my eyes looks reasonably close to Vegas Pro's output (not sure if I can really tell with a wedding). Here's my experimental workflow. There are ways to improve the workflow, but this one I'm sure works: I still have to confirm that the resultant MVC file is 25 mbps and not the default.
1) Import into Edius Pro, perform all editing and convert to 24Hz Canopus HDX files in Edius.
2) One time item in PD11 - Prior to importing any files, go to "Produce", then select "H.264 AVC". Select the 16mbps 24Hz selection from the Profile Name drop down. Press the + button shown to the right of the profile name. Go to the video tab and change the average bitrate to 25000 kbps. Make any other changes in video and audio tabs and then change the profile name and press the "OK" button. You now have a custom built profile.
3) In PD11, go to the disc menu and add the video files created in Edius Pro (Canopus HDX files). Add them in the order you would like to see them on the disc or move them around after loading the files.
4) Highlight one of the video files in the upper left window and go to the Produce tab. Click on "3D". Select H.264 AVC, then H.264 Multi-View Coding for the output type. Select a Profile Type of "Custom" and then select the profile created in Step 2.
5) Change the "Output Location" of the Production in the lower section of the window. PD11 will produce the first file as "Produce" and the second file as "Produce_0", unless you rename the files.
6) Press the start button and allow rendering to occur. Afterwards repeat steps 4-6 with the next file until all video files have been produced.
7) Go to the Disc tab and delete the names of the files you previously added. Add instead the newly created "Produce" files. These are now rendered with the higher bitrate.
8) Update the menus with menu preferences
9) Select 3D Disc and then select "H.264" for encoding type and "HD 1920x1080/3D" for the quality. Select 3D-BD for the output format. Press the "Burn to 3D" button to start. I usually just make an M2TS file and then use Imgburn (twice) to first create and .iso file and then burn the .iso fille to disc.
Notes: The Preview in PD11 will show the menu in normal 3D but for some reason the higher bitrate files look like partial 3D screens. Not sure of the cause of the preview problem but the disc is burned correctly.
When going from the 3D menu to the 3D video, the projector is indicating that it still gets 2D frames in between. So, please compensate for the delay in getting a picture when the 3D BD starts playing the program.
I've done this workflow with two 5-minute test files. Those worked fine. I'll try the next burn with the full length files.
post #1977 of 2065
That's encouraging. Thanks for the report, Andy. Have you noticed any "juddery" artifacts with faster motion? Any way you could produce a smaller video so we could download and check it out?
post #1978 of 2065
Nice workflow, similar to what Don has developed earlier with Vegas and the PD10.
How have you rendered in Edius to the HQX codec? As side-by-side full or top-bottom-full? If you use side-by-side half, you could also do that with the Canopus HQ codec (what does not allow to go beyond 2K).
post #1979 of 2065
I been using Edius Canopus lossless. Each file is over 1gb, but looks pretty good in PD11
post #1980 of 2065
Now that I have everything working, I'll try some experiments with the Canopus output to see how the different options end up looking.
My first attempts were with two 5-minute files and that was still 1.5 GB. Really what I want to confirm is the output format. It looks like for about 50 minutes of 3D video with three 3D menus with motion video, PD11 is going to take about 44 minutes to generate the BD folder which is 12GB in length. This is 2GB bigger than when I had tried this with the "standard bitrate" 24Hz files, which is a good sign. But, I still haven't confirmed if PD11 disc burn is re-rendering the high bit rate files or using as-is. However, the results look good on a 114-inch screen, so maybe that is a good enough answer.
This burn is the first that I'm trying the DTS encoder from PD11. Normally I use a stand-alone DTS encoder, so it should be interesting to hear how this version turns out, as well.
Edited by alk3997 - 11/16/12 at 6:21am
  Back to Forum: 3D Source Components
