AVS › AVS Forum › 3D Central › 3D Source Components › JVC GS-TD1 3D-Capable Camcorder
JVC GS-TD1 3D-Capable Camcorder - Page 11
post #301 of 2068
Originally Posted by Frank View Post
The problem seems to be that the files lose chroma information when played back through the computer. This needs to be solved.
I get the same thing when attempting to play back the footage in 3D mode in both power dvd and and stereoscopic player.
Turn off the 3D mode and it appears as normal good quality 2D. The various 3D players simply do not understand the frame packed interlace.
post #302 of 2068
Originally Posted by bigbarney View Post
Vegas pro 10 is much further advanced than magix is. Vegas simply has a problem with the mp4 container that the jvc file is wrapped in. That can be solved however by re-wrapping it in a m2ts container with TSmuxer. Fruitless effort however since the frame packed interlace is not recognized and the file is simply seen as normal 2D
Just about any player seems to play back the jvc mp4 files in 2d.
The problem is in finding a player which contains the MVC codec (which doesn't seem to exist).
In any event... magix is not the answer
Both PowerDVD 10 Ultra and TMT5 play the MP4 in 3D although with somewhat decimated chroma.
The thing is, even the AVCHD file the camera produces does the same thing!
post #303 of 2068
Frank, do either of these program let you export L/R from the mp4? At least playing it is a step in the right direction!
post #304 of 2068
This is an unaltered clip in AVCHD format from the JVC. It suffers from the same reduced chroma effect when I play it.
http://dl.dropbox.com/u/7350380/R2D3.MTS
post #305 of 2068
A definite No to that.
Would certainly be nice...
post #306 of 2068
No.
So far I have found NOTHING that understands mvc mp4 frame packed interlace.
The same questions have been asked on the doom9 forum (these guys are pretty good at getting around this sort of thing) to no avail.
post #307 of 2068
When I play that in a normal 2d player (nero showtime for example) I see normal hi def 2D quality. It becomes a mess however when played back in a 3D player.
post #308 of 2068
I don't get it!
I've played it using Stereoscopic Player, TMT5 and PowerDVD 10 and the chroma is messed up on all of them in 3D mode.
This is supposed to be a standard AVCHD sbs file so what gives?
post #309 of 2068
I don't get it!
Sorry... my mistake... I thought this was R2D3.MP4. I hadn't noticed the MTS extension.
When I play that on nero showtime I get a normal sbs shown in 2d view (color looks fine). I can also load that with no issues into Vegas and render it out. It also plays back fine through the PS3 onto the tv. The 3D effect is there and looks fine... it's just no full res.
post #310 of 2068
I just shot a short video in AVCHD mode and played it back from the camcorder directly to my UN40C7000 via HDMI and it looks beautiful!
Frank Make up your damn mind .Either its god aweful as you mentioned earlier. Or it looks beautiful in the statement above. Is it what you consider NICE. To much up and back here by one customer.Bravia has one and said the vids he made were awesome. What gives here.
post #311 of 2068
It appears to have significantly less chroma resolution then it should have to me.
post #312 of 2068
How about this one. The loss in resolution seems very obvious.
http://dl.dropbox.com/u/7350380/JVC%20shoots%20R2D3.ts
post #313 of 2068
Well, I'm not the best one to compare to what has really been shot since I didn't shoot... but to me it appears normal. The red brick is clearly red... the dog appears proper color for the type it is... etc. It's definitely a better quality than the Panasonic.
post #314 of 2068
I'll let you know in about 20 minutes.
post #315 of 2068
Again... to my eyes the color looks good in both R23D.TS and R23D.mts
Now the resolution is not quite there... I'll give you that much. Certainly not 1920x1080 resolution... but then it's not 1920... it's 1/2 of that so there is no way it will ever appear to be full resolution.
post #316 of 2068
Here's a screen grab from the panasonic;
post #317 of 2068
Look at this one which is from the twin cam vehicle.
http://dl.dropbox.com/u/7350380/R2D2_test1.ts
post #318 of 2068
Holy **** JOHNNY5 IS ALIVE. WTF. Funny stuff looks good to me and i have bad eyes
post #319 of 2068
I put it all on the big screen for the wife to watch (her eyes are better than mine at this sort of thing)
She did not notice any real difference in color or quality or resolution. It was sort of tough to judge though because of the snow involved in one of the videos (large white areas tend to make other colors appear to be more vibrant). The one that R2D3 shot however (R2D3_test1.ts) did have more 3D depth to it. I would imagine that's because the lenses are further apart on R2D3 than that of the JVC.
Screen grab from R2D3
post #320 of 2068
All of this is really kind of a moot issue though I guess. From my point of view it's all wasted money if I can't get full resolution off the cam and onto a disk. If I wanted crappy 1/2 resolution then I would have purchased the Panasonic some time ago.
post #321 of 2068
Thanks for doing that for me.
I'm more confused then before if that's possible.
When I play a video straight from the camcorder via HDMI, it looks great and when I play exactly the same file through the computer it looks bad.
Arrrrrrrrrrrrrrg.
I'm determined to figure this out sooner or later.
Believe me, what you are seeing pales in comparison to what comes straight out of the HDMI port.
post #322 of 2068
What you are referring to as crappy 1/2 resolution looks to me fantastic when viewed directly from the HDMI of the camera and way better then what you are seeing from my downloaded files.
post #323 of 2068
Well... through HDMI is a different story all together. I would HOPE there to be significant improvement.
I however tend to put all my stuff on blu ray (or stream from the HDD) after some editing.... so I need a way of getting the full res off the cam. If I can't, then it's useless to me.
post #324 of 2068
By the way, that last file I posted from the twin cams looks unbelievably good when viewed using the raw left and right files played through Stereoscopic Player and better then the best video I've seen from the JVC, whatever that means.
When rendering it as a AVCHD 1/2 res sbs file a lot more is lost then just half the resolution IMO.
post #325 of 2068
But why would there be?
post #326 of 2068
Is this in avchd. And you can burn the avchd to a disk.Correct. Sounds ok to the average user to me.
post #327 of 2068
Yes and I do believe the average user would love this camera without question.
post #328 of 2068
There is probably some validity to that.
Not only are the L and R views brought down to 1/2 res in order to fit in one frame... but they're also 'squashed' horizontally so they appear normal when each 1/2 frame is expanded out to 1920. That 'squashing' effect must play some kind of roll in quality reduction.
post #329 of 2068
Call Peggy she will help.
post #330 of 2068
But the squished 1/2 res recorded in AVCHD format by the camera looks fantastic when it's output by the camera via HDMI and yet not near as good when played by any computer software.
That is what bothers me the most right now.
  Back to Forum: 3D Source Components
