AVS › AVS Forum › Audio › Receivers, Amps, and Processors › DTS Neo.X
DTS Neo.X - Page 5
post #121 of 902
Originally Posted by SoundChex View Post
So what happens if a (discrete) DTS-HDMA 7.1_Front-Wide soundtrack is decoded by an AVR with a DTS-HDMA+Neo:X decoder on a system equipped with Front Wide speakers? Does the original fully discrete 7.1_Front-Wide soundtrack (as authored on the BD) ’reappear’ with NO mixdown-to-5.1_Standard-plus-Neo:X-'synthetic'-expansion to ’degrade’ it?
"Last Action Hero" in SDDS-8, anyone?
AJ
post #122 of 902
Since the beginning of DTS-HDMA, it has been possible to author BDs in 7.1_Front-Wide configuration (with the mandatory 5.1_Standard ”mixdown” available for non-7.1_Front-Wide-’ready’ systems); as there were no(?) AVRs capable of decoding (more accurately: "capable of reproducing in full") DTS-HDMA 7.1_Front-Wide soundtracks, there was (until now) presumably no incentive to author soundtracks using that configuration!
So what happens if a (discrete) DTS-HDMA 7.1_Front-Wide soundtrack is decoded by an AVR with a DTS-HDMA+Neo:X decoder on a system equipped with Front Wide speakers? Does the original fully discrete 7.1_Front-Wide soundtrack (as authored on the BD) ’reappear’ with NO mixdown-to-5.1_Standard-plus-Neo:X-'synthetic'-expansion to ’degrade’ it? If so, then perhaps we might look forward to some concert footage reissues in DTS-HDMA 7.1_Front-Wide, where they could really shine!
Where does one get a DTS Master Audio 7.1 Front-Wide soundtrack as a source...
Though DTS demonstrated certain source materials in DTS Master Audio encoded with Front-Wide, Front-Height tracks @ the Hollywood Recording Academy many months back..
There has been no commercial release of such tracks or mixes to my knowledge....
The only source would be to know somebody inside DTS to
borrow a few..
Just my $0.02...
post #123 of 902
Originally Posted by WiWavelength View Post
"Last Action Hero" in SDDS-8, anyone? AJ
While my post was intended address the question of "conserving' discreteness', it's likely that "Last Action Hero" (not the worst movie ever, although I seem to recall it featured in the Razzies the year it was released . . . 6 Nominations, No "Wins") will be remembered most for showcasing "Hollywood couple" Arnold Schwarzenegger and Maria Shriver!
post #124 of 902
Dolby 70mm Six Track films in formats 40, 41, and 44, as well as all SDDS-8 films, have five screen channels: L/LC/C/RC/R. However, you could certainly argue that L/R channels in that configuration do not truly correspond to FWL/FWR channels in a front wide configuration.
AJ
post #125 of 902
The only source would be to know somebody inside DTS to borrow a few..
Just my $0.02...
The DTS-HDMA Encoder User Manual seems to indicate that 7.1_Front-Wide was fully implemented as an encode option (although I have no personal experience as to whether the software capabilities mirror the DTS-HDMA Encoder User Manual 'promises'...!?) Plus, it seems to me that there is conceptually not much difference between downmixing the (say) 20 on-stage miked tracks from a concert to produce the L|C|R stems for a 5.1_Standard mix vs the LW|L|C|R|RW stems for use in a 7.1_Front_Wide mix. Unless the is some reason not to remix the concert audio...?
post #126 of 902
So what happens if a (discrete) DTS-HDMA 7.1_Front-Wide soundtrack is decoded by an AVR with a DTS-HDMA+Neo:X decoder on a system equipped with Front Wide speakers? Does the original fully discrete 7.1_Front-Wide soundtrack (as authored on the BD) 'reappear' with NO mixdown-to-5.1_Standard-plus-'synthetic'-Neo:X-expansion-to-7.1_Front-Wide 'degradation' consequences?
No. The decoder knows the difference between Lc/Rc and Lw/Rw, and will not rescramble the signals to use the 5 available speakers. It will play the SDDS Lc/Rc channels thru L/C/R same as any other 5.1 system.
post #127 of 902
Pioneer's DTS Neo:X equipped SC-LX85 AVR includes appropriately labelled (full 11) sets of both pre-outs and speaker terminals, although the AVR is described as 9.x. Hopefully this indicates that the owner can attach all 11 speakers, and choose between several "9 speaker" configurations on a movie-by-movie basis...?
post #128 of 902
Are there going to be in the future or is there work going on currently on DTS HD MA movies Soundtrack which includes Discrete Soundtrack for Front Height, Front Wide Channels which can be used in DTS Neo X ?
Rana
post #129 of 902
Rana
Hi Rana,
I have no information regarding what DTS is working on, but if there were to be a revision to DTS-HD master audio to increase the number of discrete channel (and if the Blu-ray standards were also expanded to accommodate more than 8 channels) there would be no need for DTS Neo:X surround processing to be used.
There is an analogous situation today for 7.1 content. I use Dolby Pro Logic IIx surround processing as a listening mode preset on my preamplifier. When the preamplifier receives a 5.1 DTS-HD master audio source, Dolby ProLogic IIx is invoked to derive the surround back channels. However, when the preamplifier receives a 7.1 DTS-HD master audio source, Dolby ProLogic IIx is turned off, that is there is no need for it since the extra channels are being provided. The same would be true for DTS Neo:X. If the extra channels were being provided in the source there would be no need for Neo to be used.
Larry
post #130 of 902
Rana
Hi Rana,
There is an analogous situation today for 7.1 content. I use Dolby Pro Logic IIx surround processing as a listening mode preset on my preamplifier. When the preamplifier receives a 5.1 DTS-HD master audio source, Dolby Pro Logic IIx is invoked to derive the surround back channels. However, when the preamplifier receives a 7.1 DTS-HD master audio source, Dolby Pro Logic IIx is turned off, that is there is no need for it since the extra channels are being provided. The same would be true for DTS Neo:X. If the extra channels were being provided in the source there would be no need for Neo to be used.
Larry
post #131 of 902
You still seem to be confusing different technologies. Neo:X is matrix surround processing that extracts height and wide information. As Larry pointed out, there would be no need to use Neo:X if the soundtrack already has discrete height and wide channels.
As for content, the answer hasn't changed since you asked the same question two weeks ago:
Will movie studios actually put in Height and Wide discrete info/channels in the near future ? Is there already work going on on this with some upcoming movies ?
No.
post #132 of 902
hi larry & sdurani,
thanks for the nice explanation. I understand this better now. I thought DTS Neo X was a format.
But if i have understood you correctly then.....
- Currently a Bluray Disc can only hold 8 channels.
If there's going to be Discrete Front Height & Front Wide channels then there will have to be a new version of the Blu-ray Disc.
Hence...
There will have to be a new version to a Blu-ray player which can De-code the newer Blu-ray Disc which has more than 8 channels.
Hence...
There will have to be new AVRs which can accept/decode more than 8 channels.
Am i correct ?
post #133 of 902
Yes.
Didn't we just straighten this out a couple weeks back:
Guys thanks, I understand this better now. DTS NEO X takes anything thrown at it and makes it 11.1 and the source does not matter.
post #134 of 902
Yes.
Not necessarily. BD can carry more channels than 8 if the spec is changed.
New discs would be compatible with existing players and AVRs. And existing players could output the additional channels via bitstream mode to new AVRs. If you want PCM from the player, then a new player will be needed that can decode the new channels.
Only if you want to hear the additional channels. That will be true whether the method is discrete or Neo:X.
post #135 of 902
Wow wee..
40 Amplifier channels..
I too have many channels, but in my listening tests of DTS NEO.X, I am attached to their 9.2 configuration as this provides my listening room a slightly, more lively soundstage then their 7.2 configuration.
IMHO...
The 7.2 configuration will satisfy the majority of the markets while not requiring additional amplifier channels above the present 7..
I am using the same loudspeaker for all 7 channels as I don't want to mix brands/models of different loudspeakers. Also my (2) subwoofers are matched as well.
Just my $0.02...
Hi M Code;
I see you are testing Neo:X. Thought this would be a good place to ask what your 9.2 speaker layout is. There must be a range and optimum location for the height and wide speakers on this. Neither the Onkyo nr1009 or the DTS site explain speaker location for Neo:X 9.2, that I can see?
I'm guessing they gave you some info. on this for your test setup.
Terry
post #136 of 902
Hi Roger,
Since you indicated here that you now have a 1009, so would it be possible to have some feed-back on your first impressions concerning DTS Neo X?
Many thanks in advance.
Hugo
post #137 of 902
+1
m dying to read a review of the NEO X.
Also on how it fares against DSX and IIz.
Can't even find any professional reviews of the 1009 or NEO X yet...
post #138 of 902
Originally Posted by Hugo S View Post
Hi Roger,
He gave some feed-back here:
Originally Posted by Roger Dressler View Post
I'm right now checking out an Onkyo TX-NR1009 AVR for my brother, and it has the new DTS Neo:X. As a surround decoder for 2-ch sources, the soundfield it portrays is not very different from Neo:6, meaning it does not improve upon it, which I think is a bit of a lost opportunity. That aside, it dramatically improves upon these side effects. It's not perfect, but one can actually listen for long periods with no trace of that weirdness catching your attention. In that respect it is finally on par with PLIIx. Only took them 11 years to get there.
Hopefully Roger can elaborate further, with a more detailed impression.
post #139 of 902
Originally Posted by sdurani View Post
He gave some feed-back here: Hopefully Roger can elaborate further, with a more detailed impression.
That same post has more of my thoughts about the improvements of Neo:X over Neo:6 within the confines of 7.1. Just today I am running in 9.1 so have not done enough yet to report any impressions.
post #140 of 902
What I would like to know, is will there be any Neo:X-equipped recievers with 11 amplified channels available in the near term?
Onkyo 5009, perhaps?
post #141 of 902
Originally Posted by KLee View Post
What I would like to know, is will there be any Neo:X-equipped receivers with 11 amplified channels available in the near term?
Although any "Neo:X 11.x capable" AVR would presumably also function in all the usual configurations from 2.0 up to 11.x, there would be 'some' weight/size and manufacturing cost penalty over a similar AVR limited (just) to the three different 9.x speaker configurations . . . and I have to wonder how many additional unit sales the extra (11.x) functionality would deliver, based on the real current year consumer demand for a "Neo:X 11.x capable" AVR...?!
Don't forget, it's likely that more people will be stepping up to a DTS Neo:X AVR from a 5.1 speaker configuration than from a 7.1 setup. So it will be 'easier' to contemplate buying 4 new speakers for 9.1 Front-Height+Wide than 6 additional speakers...?!
Plus, this way, the CEMs get to take 'two bites':
  • (2011) "9.1 is the new 7.1/5.1''
    and...
  • (2013 ?) "11.1 is the new 9.1/7.1/5.1"
Remember, the CEMs need to find a new "next big thing" every year to refresh (consumer) AVR demand! But there's no need to rush through all the step ups at once . . . there's plenty of upgrades to get through before we reach 22.2 channels/speakers (for SHV) in around 2025!
post #142 of 902
Good excuse for the industry to start using more digital amplification. Remember those pancake-thin receivers from Panasonic?
post #143 of 902
Is DTS Neo X going to blow away Audyssey DSX and Dolby IIz ?
post #144 of 902
No.
In my opinion, DSX is more detrimental than useful, tilting the front/rear balance forward and adding extra bass; and Neo:X is not as good as PLIIx for existing content -- narrow surround effect and weird timbral changes to certain instruments.
This is when using wide speakers in a 9.1 setup. I have not tried height speakers yet.
An as yet untapped capability of Neo:X and to a lesser extent PLIIz is the ability to encode specific height/width cues and recover them. This is something DSX cannot do. Until someone makes such newfangled soundtracks, we won't know if that blows away anything, or just blows.
post #145 of 902
Does anyone know HOW the extra channels are matrixed onto the 7 channels on the media if it is Neo:X encoded?
I have a couple of stand-alone matrix decoders not currently in use that I could imagine hooking onto the pre-outs and decode these channels myself...
post #146 of 902
To my knowledge, there is no media that is DTS Neo.X encoded.
The DTS Neo.X source material we received for evaluation was provided by the DTS marketing team. I understand that there has been some internal loan-out of some DTS Neo.X encoders but no commitment yet for commercial release.
However..
Like other matrix systems such as Dolby Pro Logic IIX...
DTS Neo.X can work well as an open-ended decoder.
But the final sonic soundstage will have varying outputs, the advantage of using DTS Neo.X encoded material is that the soundstage is more predictable for separation and instrument placement...
Just my $0.02...
post #147 of 902
Yes, I'm well aware of that... but the standard has to be set since there's already a receiver on the market and more coming out soonish... And even if the encoders are not yet for sale/in use - the function of them has to be fixed already...
So the question is... which channels are supplying what to generate Front wide and Front high?
( Please give me some leeway languagewise, I'm not an english native. )
post #148 of 902
Yes, the standard has been set. But since it is proprietary, DTS are under no obligation to reveal how it works.
post #149 of 902
Sure, if they don't tell there's not much we can do, especially if they've done it so complicated we cannot reverse-engineer it. But as it's supposed to be able to do something even with non-encoded material, it's bound to be logically tied to the information in the nearest channels, right?
But I guess I'm way too early with my questions... It's just that my current receiver is dead and I would like to buy something that exists now, not in 3 or 8 months from now... and as I believe Neo:X having a big chance of becoming a standard to reckon with during the lifespan of my next receiver, it would be a good thing if I could find out now, that I can find a way to decode it even if what I have to buy can't do it on it's own... (Onkyo 1009 is missing other things I want, so it's not an option. And no one can tell if Denon will make Neo:X available to 4311 by way of firmware upgrade. Pioneer LX-85 might be something to wait for, but I worry about the new classD amps in it and I'd much rather get something with Audyssey XT32&Pro capabilities...)
post #150 of 902
I suspect it would be wise to assume that the content of ALL (non LFE) input channels plays some part in the computation process that delivers the 'added' output channels, whether the content of the input channel is itself modified ('steered') by the DTS Neo:X expansion process, or not modified (as might be the case for the L|C|R channels...?)
