Originally Posted by sdurani
I can't see why room size would be a factor when it comes to the benefits of overhead speakers. The easiest and most reliable way to get stable imaging above you is to simply place speakers above you (makes it difficult for those sounds to come from any other direction). Whether those speakers are 5 feet from you vs 15 feet from you isn't as important as having height effects achored to that location (overhead).
VOG will not be 5 feet, that's the whole problem. Say you're ceiling is a lowish but common 8 feet. Your ears are at about 3'4". Then take the speakers physical size into account and you're at less than 4 feet. Not enough to allow for proper blending of highs & mid/lows. Maybe some dipole design might be better suitable for this?
Not so sure it would be worth the $1.2k the speakers would cost to try something that's not yet standardized...
