Hi
I have a pioneer pdp-435.
I'm experincing some problems with my plasma. I have noticed the issue before, but a recent change in my av-setup have caused this to be a problem.
My setup is that I have:
- a htpc connected to my receiver (marantz sr7005) using hdmi.
- a wii connected to my receiver using component
- a xbox connected to my receiver using component
-my receiver connectd to my plasma using hdmi
I just recently bought the receiver.
The problem is that my plasma goes into some error mode when I switching input source on my receiver.
The symptoms I have seen is:
- if i connet my pc directly to the plasma using hdmi out, the plasma will (sometimes) be turned off and go into error mode if the pc tries to send a 'monitor off' signal to the plasma.
- in my regular setup the plasma will (sometimes) be turned off and go into error mode when switching input
sometimes is undefined, maybe 50pst of the times.
error mode means that the screen is off and that the on/off button blinks red and the screen does not respond to the remote. I have to turn the display completely off and then on again using the actual on/off button on the screen to fix the problem.
Can anyone adwise on a possible solution to this?
