well...just for fun I wanted to find out if the MFW-15 driver was blown or not...it looks like the driver is FINE.
I hooked up the Turbo Dayton SA1000 amp to the stock driver leads...sub works fine. Actually it sounded great. I didn't want to turn the gain up too much so as to not blow the thing out of the cabinet, but...this has me thinking.
I think if you have a blown amp you could EASILY use almost any other external amp to power your MFW as long as your driver is good. I'm going to try later with an older Sansui 120wpc amp I have just to see how it works.
I think this is GOOD NEWS for those with blown amps that don't want to spend too much $$$ on getting their subs working again. It would be easy enough to leave the stock plate amp on, but remove the INPUT board so you could just run speaker wires into the sub and hook it up.
If you really wanted to give it some juice I'm thinking almost any Behringer A500 watt amp which can be had for around $100.00 would work great. I'll report back when I've done some more testing..inbetween Football of course!
