AVS › AVS Forum › Audio › Home Theater In A Box › AV Sync Issue...Onkyo Receiver the problem???
post #1 of 3
Hello All,
Last night I tried watching Anchorman on Blu-Ray. However, my A/V sync was off and I tried tweaking certain settings to help it out but to no avail. Also I notice it slightly with Gangs of NY Blu-Ray.
My Set-up: Samsung PN50C8000 TV, PS3 Slim Blu-Ray player, & Onkyo HT-7300 H.T.I.B. (receiver is Onkyo HT-R680). All Audio options on PS3 are set to bitstream.
To try and combat the sync issue I did the following:
Pause movie and try to let it catch back up,
Restart TV, PS3, Receiver multiple times
Turned the pS3 1080p/24 option from "On" to "Automatic"
Turn off Cinema Smooth Processing on TV
Disabled HDMI A/V Auto Sync on Receiver, Renabled once I figured that didnt make it work
Manually adjusting the delay time on receiver (goes in frequency of 10ms) from 0ms to 10ms to 20ms....the higher it got the worse it looked.
It seems as though I needed it to be set to -10ms if I had to describe how it was off.
Anyone have any similar experiences (preferably with a similar setup no biggy though if you have a different set up)? I feel like I did a bunch of things to offset this issue but it is still showing a difference. Anyways to make my Audio/Visual set up sync up better? Do you think this is my receiver taking those extra milliseconds to decode the audio from the PS3? The audio for this blu-ray is DTS Master HD.
Sorry for the long winded post but any help would be greatly appreciated. I posted this in Blu-Ray section bwcause I am unsure is my PS3 slim is what needs to be adjusted and figure you guys would have the best overall insight.
MP
post #2 of 3
Is the sync issue blu-ray exclusive or are other inputs affected as well?
post #3 of 3
Hey MandM,
Only with blu-rays, I adjusted to the a/v delay to 200ms (highest on my receiver) and it actually fixed the problem....weird considering it looked awful when tresting it out at 50ms or 60ms or even 120ms...
  Back to Forum: Home Theater In A Box
