AVS › AVS Forum › Display Devices › Display Calibration › New AccuPel owner and product
New AccuPel owner and product - Page 2
post #31 of 50
No nothing works on the desktop pc it works but not on my laptop !
post #32 of 50
It works on your desktop PC, is that correct?
But it doesn't work on your laptop, is that correct?
Are both desktop and laptop running the same version 7 of Windows?
post #33 of 50
Yes,still nothing !
post #34 of 50
Try starting the program without any USB devices connected to your laptop and see if it comes up working in demo mode.
post #35 of 50
i have try an other laptop and the result is the same !
post #36 of 50
Did you try it with no USB devices connected?
post #37 of 50
yes, it does not matter !
post #38 of 50
Tom sent me your email address so I will contact you.
post #39 of 50
Ok
post #40 of 50
Free Firmware update is available for the AccuPel DVG-5000 Owners (New Version 09/01/2012)
See the Support tab below for information about a new firmware update.
http://www.chromapure.com/products_accupel.asp
The latest firmware (09-01-2012) includes two new features.
• First, the levels of the surrounds in window test patterns are now user-defined. By default, windows are black, but the user can now define them for any level desired.
• Second, users can now apply a single color (RGBCYM) to any of the gray test patterns in the AccuPel, effectively creating hundreds of new test patterns.
post #41 of 50
New Firmware available for the AccuPel DVG-5000
This firmware adds support for user-defined window sizes and checkerboard test patterns.
See the Support tab on the AccuPel page for details.
This firmware is a free download for all AccuPel DVG-5000 users. Support for the new feature will be available soon in ChromaPure.
post #42 of 50
Odp: New AccuPel owner and product
Tom, do you ever plan to add support for 4K resolutions to DVG-5000?
post #43 of 50
Given the processing power of an existing chassis for a VP or signal generator plus output bandwidth limitations, I would suspect any existing 2K video processor or signal generator regardless of the manufacturer could not be upgraded to 4K but would require a new chassis.
post #44 of 50
We cannot simply upgrade the DVG-5000 to support 4K. That requires new hardware. So if we ever do this, then it will be a successor to the DVG-5000.
post #45 of 50
This sounds like a plant post, but it isn't. If AccuPel comes out with a 4K signal generator some day, do you expect that there might be a trade in program for those owning the existing 2K generators?
post #46 of 50
post #47 of 50
This is way too speculative and too far in the future to even consider right now. I will consider this if and when we ever release such a product.
post #48 of 50
That sounds like a yes. smile.gif Obviously, for people buying right now up to release if any of a 4K product they might seek some asurance that they will not be harmed by not waiting.
post #49 of 50
Oh, i thought any 1.4 hdmi equipped device is able to output 3840×2160 signal. It`s in hdmi spec.
post #50 of 50
No one said it wouldn't. But it is fps limited currently. It will do 24 and 30, but if I remember correctly the bandwidth of the existing HDMI chips is not wide enough to handle more. The processing power of the generator is not sufficient to generate a 4K pattern. One needs a much more powerful chip.
