Hi everyone
Firstly what a fantastic resource this forum is ... but it can be daunting trying to find very specific information (as is the case with all large resources like this). I've done quite a lot of searching but haven't found the info I'm looking for so I figured I'd ask for some pointers in the right direction.
I've have my new PJ (Vivitek H1080FD) in my room and am reasonably happy with it as far as band for the buck (the RBE is a bit annoying but I think I can live with it). My current screen is a smaller 4:3 Screen Goo Digital Light Grey setup (I know you folks don't like Goo very much but it worked for my needs and was easy). With the new PJ I want to setup a 120" 16:9 screen and have been doing a bunch of research on how I want to proceed. I'm not really interested in going the painted route (Goo or DIY) if I can avoid it ...
I think I'd like to try doing my own frame + mount setup and use Draper HiDef Grey but I'm concerned over how to physically mount and tension this stuff. I spoke to a sales rep and can get a good price on the screen material itself but he cautioned that this type of screen material doesn't tend to do well if you do the staple/thumb tack route when mounting -- it's apparently very prone to ripping when using this approach
I hate to have to spend an extra $1000 for one of their mounting systems if I can build my own .. and it's literally over $1000 more for their cheapest fixed screen setup (that uses the exact same screen material)! ~$250 cdn shipped for the material vs. ~$1400 CDN for the same material in the Shadowbox Clarion frame! I know that a good frame is a good frame, but wow ... hoping that this might be a likely place to save some $$ and still have a really nice screen material to work with ...
Can anyone give me pointers on how best to mount and tension this stuff? I've seen quite a few of the builds here and was thinking that I'd do a "2 piece" type unit, meaning one frame to mount to and tension with, and a secondary frame to hang in front for my borders, etc. Apparently I may also be able to get some materials with grommets in them already but the price is also considerably higher and I can't get the HiDef Grey (which I've seen in the showroom with a very similar PJ and it seems like the right material for me).
Any pointers? I'm pretty handy with building things and have friends willing to help that are even better at this sort of thing than I ... so I'm less worried about being able to do the construction and more worried about ripping/splitting the screen material by not taking the right approach for mounting it!
I also figured that not a lot of peeps here had tried anything like that. I think the sales rep that I was dealing with was actually quite an a$$hat after having met him in person (sort of) ... I ended up driving to their location to pick up a screen that they had in stock ... but it turned out they didn't have it in stock, but it took almost an hour dealing with his lackey to actually find that out. They are an online dealer located near me that shall remain nameless .. but for some reason they change their name and web address every couple of years LOL... having dealt with them personally at their "show room" I understand why. THe lackey spent about 20 minutes trying to even get the Control4 automation system to work in order to turn on the projectors in the room ... none of which were even calibrated and one of the 3 wasn't even properly aimed at the screen.
