AVS › AVS Forum › Display Devices › Rear Projection Units › Optoma hd66 overheating
post #1 of 2
Hey guys, I have an optoma hd66 that keeps overheating. We will be playing a game and the screen will just shut off. The light on the top usually glows green, but in this condition it turns red. I've let is set for about an hour and it does nothing. So after you unplug it and plug it back in it turns back on with no problem. Anyway I am just wondering if anyone else has had a similar situation or knows of a solution. Thank you for your time.
post #2 of 2
You are in the wrong forum, try Front Projectors.
  Back to Forum: Rear Projection Units
