which HDTV antennas are rated best for both indoor and outdoor use?
i have the option of placing a roof top antenna, will the picture quality be better from a roof top antenna vs. an indoor antenna? also if i were to go with the roof top antenna is there a maximum distance that i can go with the cable before deterioration starts? additionally for indoor models is an antenna required for each tv?
i just found this site- it's great
thank you
thank you
I always recommend an outside antenna (federal law allows it no matter what your HOA or deed restrictions say)..how far are the transmitter towers from your location? You can use TVfool to see where they are in your area..you may or may NOT need a preamp....if you DO use one, DONT go with Radio Shack...use quality Channel Master or Wineguard..you'll be happy you did. Antenna depends on how much you want to spend and how much room/etc you have..You CAN over do it on the antenna as well...(though the RS VU90 or CM3016 are average...but they include elements for lowband, TV 2-6, which is basically not used in most areas...again, your own situation will vary)
