Hi All,
I've recently discovered this forum and its clear that no one knows projectors better than the 'avs' community...
So here's my situation. I'm planning on building a Formula 3 racing simulator as I've gotten hold of a damaged tub (monocoque chassis) which would make an ideal platform. I'm really trying to find the most effective and efficient method of giving the driver a sense of immersion, and it seems like projectors are the way to go. Clarity and sharpness is a must (HD 1080p 1920 x 1080?), and I'd like to have a 1:1 view to help the driver think that he is driving the real thing (I intend on lining the tub up with the on screen image).
I've had a look into 3d, polarized method and shutter glass method, but I'm uncertain as to whether this is compatible with the game 'rfactor' and if the results will be good enough to use? I've read that polarized comes with its drawbacks such as ghosting and cross over, and shutter glass could have negative medical effects due to blanking one eye out 50% of the time?
The other option is obviously 2d, in the form of curved or flat screen, 1 or 3 projector config. One problem I do have is that I would like to place the tub as close to the screen as possible to help immersion (<2metres). This would mean that if I'm projecting an image from the same side as the tub ( front projection if I understand correctly?) then I would have to find something that can project at such an angle as not to cast a shadow onto the screen.
I'd like to have a full 180 degree FOV, but am unsure as to how complex this task is? If I had to go down this route, I suppose I could invest in a lower cost projector as I'd be using three of them together and each one would be projecting a smaller picture?
I've had a look around for projectors, and there seems to be a great deal of them out there! The panasonic AE4000U caught my eye if I decide to go down the single projector flat screen route? Would this be suitable for my application? I forgot to mention that the room is not the biggest around, I'd say maybe 15 feet long? I'm really struggling to pin down the properties I need in a projector, apart from the 1080p HD, I suppose throw distance and lens shift would be critical?
I imagine the other option to avoid the shadow problem would be rear projection, but how much throw distance would you need in this case, as I'd still have to place the racing tub on the otherside which technically would divide my room into two halves with the screen in the middle?
As for screens, I've had a look at a number of DIY screen builds on here and I might try my hands at building my own. The only problem is that I m located in the UK and the materials mentioned on here are normally from shops specific to the states.
Regarding budget, I wouldn't say its fixed, as I want to buy a quality item and not have to change it within a year. I'd say I have up to 5000 Dollars at most, but am open to opinions etc...
I've attached a picture of what the tub looks like to get an idea of the size I'm dealing with. I'm open to critisism and would greatly appreciate any advice...
Kind regards,
Julian
Kind regards,
Julian
, If someone could give me a range I would really appreciate it.
