Originally Posted by
Verge2
For 180 degrees wouldn't the projectors firing on both sides of the screen have to be very close, or the other side of the screen will be blocking the picture.
I can see how it works for 120 degrees, but it seems like 180 throws a wrench in there.
Would I be able to cross the projected images, i.e. have the projector which is throwing onto the left of the screen, to the right of the centre projector, and vice versa for the right side of the screen?
Then there s the possibility of just going 2 projector as those videos that were posted seem very good!
I have around 12-15 feet to play with, is that enough? Really need advice on what to do abou the screen. I m still thinking if I ll go 180 or just settle for 120? Also how to make the actual screen, or where to buy it from
Ahhhh so many decisions, its never ending really!
