AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Mishap with phono input
post #1 of 2
I just accidently plugged my tape deck into the phono input on the back of my denon avr-2310 not realizing until after i turned on the tape deck (Im pretty sure the entire block knows about it) the denon still seems to be working fine but im still a bit concerned, is there any risk to the receiver from this?
post #2 of 2
Not likely, especially if all appears to be working properly, although it would more likely be your speakers that might have been damaged if anything. If they're fine, then should be no worries.
For more information or questions about your 2310, join us in the Denon 2310 Owner's thread.
