Hi,
I purchased a set of Precision Acoustics 5.1 speakers which included an HDS10 subwoofer. I also purchased a Pioneer VSX-820-K receiver to go with them. I have the sub connected with a subwoofer cable only. The crossover is set to 150 Hz (the receiver's crossover is set to 80 Hz) and the volume knob is set in the middle of it's range.
In the subwoofer manual it says that when the power is set to Auto "the amplifier will turn itself off to stand-by mode if it does not sense a signal after approximately 10 seconds." So I put it on the Auto setting.
The light on the front was red when I first plugged it in. When I turned on the receiver the light turned blue, I assume to indicate that it's getting a signal. However, when I turn the receiver off the light stays blue and after about 10 seconds I can hear this constant hum from the sub. If I switch the power switch to "Off" then the hum goes away and the light turns red again. After that if I put it back to Auto the light stays red and there is no hum. Sometimes I can even hear the hum when watching a TV program that has no LFE channel too.
So it seems that it's not going in to standby? Or, since the hum doesn't seem to start until after about 10 seconds maybe it's sensing there's no signal but not going into standby properly?
Has anyone had this issue before? Any idea how to fix it? Is the sub defective?
