AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Compact Sub - Recommendations?
post #1 of 11
Hi guys, I'm looking for tight, accurate, punchy bass. I'm looking for a small sub, but I'm not familiar with the downsides of those small, under the seat subs, are those generally less accurate than full speaker/ enclosures? Or is it just a question of the amount of sound being produced?
Also, what are some good compact subs?
post #2 of 11
Budget?
Vehicle?
Listening tastes?
Amount of space you have available like mounting depth etc. MAX. I like to know max and work down from there.
I will suggest a good 8" sub in a small enclosure or better yet a 10" that likes a small enclosure.
Dayton 10HO in a small (.5-1 cu/ft) enclosure. Add a small Class D mono amp and you're pretty much good to go.
post #3 of 11
http://www.parts-express.com/pe/show...75&FTR=269-175
get this to power it. Whatever you get.
post #4 of 11
Budget: $200
Vehicle: '98 Honda Accord Sedan
Listening tastes: electronic, rock, jazz (Radiohead, Dave Matthews Band, Modeselektor, Flying Lotus, etc)
As far as available space, that depends on whether I use the trunk or not. I'm not looking for car shaking bass, I just want a respectable balanced amount. So should I still use the trunk, or would an under the seat solution still deliver high fidelity bass? That Dayton sub looks really nice, I'm just a little concerned that it will deliver too much sound.
post #5 of 11
Get the Dayton 10HO and place it in a half cu/ft-ish sealed enclosure and power it with whatever amplifier you have. Mount it in the trunk and call it a day. it will give you a solid foundation that is accurate and musical. For the money, it will be hard to beat. As for output, that is a simple amplifier gain adjustment. I will bet, that you will be driving around with it turned up while having an ear to ear grin. They are that good and I know first hand how once you have that lower octave foundation how much more enjoyable music can be.
post #6 of 11
Ok, thanks man, I think I'm going to go for it. As far as the enclosure, would something like this be ok? Maybe you could recommend something better?
http://www.sonicelectronix.com/item_...lack.html#tabs
Sorry for all the questions, it's my first time installing a sub.
post #7 of 11
Looks perfect. Make sure you pre-drill the screw holes. It will save you splitting that wood. Also test fit the sub in the hole before you drill. There is a decent return policy if the sub does not fit and you do not want to attempt modification!
Good luck!
post #8 of 11
One more question, do I need a capacitor for this setup?
post #9 of 11
God no. Save your money. Caps are a waste of money generally.
post #10 of 11
Ok one last question
Should I use any of this stuff? http://www.sonicelectronix.com/item_...iber-Fill.html
I'm planning on getting that amp you mentioned.
And also, what gauge speaker wire and power wire do I need?
post #11 of 11
That will work fine. You can also get the same stuffing at walmart around the same price. That Parts express amp may not have enough a$$ but for 10 bucks, its a cheap thing to try.
  Back to Forum: Car Audio, Video, and Nav
