I'm wondering if anyone can help me. I have a 60" TV that I watch PIP frequently. Usually for multiple sporting events.
I have my signal split and one signal is connected directly to my tv tuner and the other my cisco pvr.
Well they just cut off the analog so I connect the DTA tp the TV
Well the engineers did a bang up job, the Ir code for the DTA is THE SAME for the Cisco PVR. So if I hit channel up it changes both.
Is there a way to "change" the code to DTA. I moved the extender as far as I could away from the TV but it's not far enough.
Help!!!
TIA.
Help!!!
TIA.
